No 4 Low or Neutral .... - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-20-2010, 12:22 PM Thread Starter
NYC Diesel's Avatar
I can't seem to get my transfer case into either Neutral or 4 Low.
The issue seems to be that I cant get the down motion on the shifter. I looked underneath and all linkages look intact. What's going on is the cylinder type device that houses a spring / piston of some sort that moves the small rod down and to the notches for 4 low and neutral is seized up solid. I get 2 High to 4 High smooth as silk but can't get that down motion needed to get into the N and 4 Low notches.
I looked underneath the truck at the spring cylinder and the two rubber boots are present at both the top and bottom but on close inspection the bottom boot has a decent sized gash in it that has probably caused some corrosion that is seizing up the parts inside.
Anyone else had this problem?
I think all I need to do is get some Pblast or lube into that cylinder and work it a little but I am not sure the best way to go about it. I guess I could always remove whats left of the boots but I wanted to check in here with you guys first in case there is a simple fix for this.
I have only had the truck for about two months and it came to me with this problem.
Thanks
1997 F-250 7.3L HD Auto Tranny 4x4 Extended Cab Long Bed
NYC Diesel is offline
post #2 of 4 Old 11-24-2010, 12:20 PM Thread Starter
NYC Diesel's Avatar
Bumpin it up.....anybody?
post #3 of 4 Old 12-03-2010, 05:00 PM
Quoted: 47 Post(s)
Yeah, it's just frozen. PB should get it unstuck. Either here on the org, or on one of the other forums, there are pics from a fella who put zerk fittings on his mechanism, so he could lube his occasionally. May be best to remove it and clean it up real good; replacement one, even used, isn't cheap.
madpogue is offline
post #4 of 4 Old 12-04-2010, 05:18 PM Thread Starter
NYC Diesel's Avatar
Thanks. Thats what I suspected. As long as I have a good feeling that getting it lubed and unstuck will solve the problem I will go back at it with a mind to probably removing it to get it on the bench and clean it up good.
Anybody got any advice or cautions on doing this removal? Hints? Tips?
Thanks
