Rattling Noise - Ford Powerstroke Diesel Forum
Old 10-31-2010, 09:32 AM
Rattling Noise
Well, I keep finding new noises in my truck. The Failing DMF (which is hopefully coming out tuesday) has so far rattled, knock, and hissed. It's causing a noise similar to an exhaust leak. But now there's a new noise. It's sounds like turning a wheel bearing (dry) around in your hand. When I did my back brakes, I had the drums turned. I thought I had all the metal shavings out, but if I happened to leave some in the hub, would they eat a wheel bearing in just 150 miles? Or is this just another noise from the flywheel? It only does it when you're moving though.
Old 10-31-2010, 02:41 PM
drives a ranger
Send a message via AIM to kanuck15
it could be a bad wheel bearing in the back. easiest thing is to jack the truck up and turn it by hand and see what you get
Old 10-31-2010, 07:57 PM
How hard is the inside bearing to change? The outer bearing I know just falls right out.
