front hubs not locking - Ford Powerstroke Diesel Forum
Old 08-27-2010, 11:30 PM
so i bout the truck back in january and used 4 wheel drive a good bt pullen people out and what not. well i went mudden the other day locked the hubs put the transfer case in 4x4 and she just spun. but after i got her moven turned it around the front lock in. then tonight i needed the 4x4 agine to get someone unstuck i could not at all get the front to lock. the front driveshaft spins along with the front axles. what yall think it could be?
Thanks
Mark
Old 08-28-2010, 04:03 PM
Manual or auto hubs?
lock them in by hand and see if they work, if so, you have a vacuum problem.
Old 08-28-2010, 04:05 PM
Send a message via AIM to Jonboywv12
the hubs themselves might just be shot or need more grease....
Old 08-29-2010, 07:30 PM
ok thanks ill take a look. there manual locking so i dont think i have vac lines to them
Old 08-30-2010, 07:36 PM
ok so i pulled the hubs off today to fig out what was going on. first driver and everything was good and working good. passenger side... well i took some pics!
so what it seems to happen is the my bearing and my seal are not there/or worn out. i cleaned everything up to see if it made a differance but not realy. seems that because the bearing is shot its not allowing the "locking sleeve" to engage the axle splines. so new bearing and seal are in order
Old 09-15-2010, 09:49 PM
well i cleaned everything up and replaced the seal and bearings. come to find out i also have another problem, my axle has alota whobbling which is effecting the splines locking in. so my question is is there a bearing in the axle tube that would support that? how do you replace it? guess pull the hub and axle then the bearing and seal sit right there?
Old 10-06-2010, 11:38 PM
yes, D60 has needle bearings to support axle shafts at outbard locations.
Old 10-07-2010, 10:15 AM
so on the outer axle tube or in the hub?
