1995 5speed f250 - Ford Powerstroke Diesel Forum
Old 08-13-2010, 10:41 PM
1995 5speed f250
well i decided to change the fluid in my 1995 f250 5 speed. I just need to know what kind of fluid and how much of it does it take
Old 08-14-2010, 05:31 PM
Send a message via Skype™ to ramsdell_
You can look up all fluids and capacities on AMSOIL's Product Application Guide.
Manual Transmission: Use only Synthetic Mercon spec. No. ESR-M2163-A2 or equivalent - AMSOIL Synthetic Universal Automatic Transmission Fluid is the recommendation from AMSOIL.
Manual Transmission, 5-SPD ZF..........6.8 pints
Manual Transmission, 5-SPD Mazda..........7.7 pints
Manual Transmission, S5-42..........6.8 pints
Let me know if you would like a quote.
Mark
Old 08-15-2010, 09:29 PM
any synthetic mercon? i was told to use synthetic mercon v is this right
Old 08-16-2010, 07:40 AM
I am not sure. There has been ALOT of discussion/opinion about what to use - Mercon vs Mercon V. I found this article from 2006 that might help clarify things a bit for you - Ford Pulls the Plug on Mercon
The nice thing about AMSOIL Synthetic Universal Automatic Transmission Fluid is that it meets the requirements for both Mercon & Mercon V.
Old 08-16-2010, 05:46 PM
I went to fill it up and only got a gallon in it before it started coming out full
Old 08-16-2010, 06:53 PM
is the 7 qts for the trans and transfer case combined or am i doing something wrong i filled it up from the side plug like all manual trans and filled it up till it starts coming out. And that was only a gallon
Old 08-16-2010, 06:56 PM
wow obviously i cant read haha pints not quarts damn i feel stupid
Old 08-16-2010, 08:09 PM
LOL. For some reason they go back and forth with pints and quarts. 7.7 pints = 3.85 quarts.
Old 08-17-2010, 08:46 AM
yea thanks im just so used to seeing quarts haha
Old 09-29-2010, 11:37 AM
My truck's auto tranny seems to slip just a bit sometimes when going into overdrive and I'm hoping if I change the strainer and fluid it will help or do I have a bigger issue? How much fluid does it take?
