96 5sp grinding 3rd - Ford Powerstroke Diesel Forum
post #1 of 20 Old 07-24-2010, 12:42 PM Thread Starter
C-STROKER's Avatar
96 5sp grinding 3rd
Hey guys need a little help on this one. Ok my truck has developed a problem i change the manual tranny fluid about 4 days ago. and now my truck grind when i shift from 2nd to 3rd. and it also grind when i down shift from 4th to 3rd. Need help is it my clutch or is it the synchros.
96 f250 4x4
ZF5
4.10s
6637 intake
fpr shim
ccv mod
need a paint job mod
C-STROKER is offline
post #2 of 20 Old 07-24-2010, 06:37 PM
rolsmojave3's Avatar
Read post on other site, synchros.
1997 Ford F-350 4x4 SRW regular cab manual trans.
-4.10s, 315/75r16...getting a frame off restoration. Go fast stuff
1996 Ford F-350 4x4 SRW CCLB manual trans. CALI spec
-ATS intercooler, WW2 w/ 1.0 housing/EPBV delete, Comp 910s, SD Efuel, 3.55s, 315/75r16
2002 Ranger FX4 with manual transfer case and Alcoa's
rolsmojave3 is offline
post #3 of 20 Old 07-24-2010, 06:58 PM Thread Starter
C-STROKER's Avatar
ya i read it on psn i hope its not that. you have any idea of how much a rebuild cost
96 f250 4x4
ZF5
4.10s
6637 intake
fpr shim
ccv mod
post #4 of 20 Old 07-25-2010, 06:08 AM Thread Starter
C-STROKER's Avatar
bump..... need to figure this out
96 f250 4x4
ZF5
4.10s
6637 intake
fpr shim
ccv mod
post #5 of 20 Old 07-25-2010, 06:14 AM
ryandamo's Avatar
what fluid did you put in?
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #6 of 20 Old 07-25-2010, 06:16 AM Thread Starter
C-STROKER's Avatar
penzoil mercon 5
96 f250 4x4
ZF5
4.10s
6637 intake
fpr shim
ccv mod
post #7 of 20 Old 07-25-2010, 06:50 AM
Electrical Ogre
alberta 7.3's Avatar
Quoted: 126 Post(s)
It's supposed to be synthetic mercon, not sure if it makes a difference or not. The ZF uses friction cone syncros, so once they wear down, they're shot. A syncro kit is around $400.
Bill
1996 F250 SC/SB 4X4 XLT
1997 F250 RC/SB 2WD project
2008 F350 CC/LB 4X4 DRW Lariat, 3" cow catcher mod
2008 Ranger SC FX4
Originally Posted by weareweird69 View Post
If your posting pictures bill, everyone dim their screens, that CAT YELLOW is bright
Originally Posted by Fordman247365 View Post
Is there anything you DONT take apart and **** with?
Originally Posted by JJFLASH View Post
I still say that those Dodge mirrors have as much business on a OBS Ford as yoga pants have on a fat chick...my .02
alberta 7.3 is offline
post #8 of 20 Old 07-28-2010, 06:36 PM
What did you figure out?
post #9 of 20 Old 07-28-2010, 07:00 PM Thread Starter
C-STROKER's Avatar
im going to try differnt fluid this weekend have been just baby in it trying not to grind it in 3rd hope i just used the wrong oil.
96 f250 4x4
ZF5
4.10s
6637 intake
fpr shim
ccv mod
post #10 of 20 Old 08-07-2010, 12:28 PM Thread Starter
C-STROKER's Avatar
so here's the latest with my trucks ZF5. so i changed the oil today to amsoil full synthetic and guess what same thing is still going on. so now i am to the conclusion that it needs a rebuild i am going to take it to a tranny shop this week to get a second opinion it, also alberta7.3 do you have a site or a number that i can get to price out a rebuild kit. is that a total rebuild in parts. also since they will have my tranny out I'm going to replace the clutch. what company should i go with would like to here is people opion on the differnt makers such as luk, south bend, centerforce, valair, etc thank you guys for all of you advise.
96 f250 4x4
ZF5
4.10s
6637 intake
fpr shim
ccv mod
