Steering linkage issues
This has been going on since I bought the truck, not sure why. When you turn the wheel, the steering linkage pivots back and forth. You can hear it clunk inside the cab when it does it. I have made sure everything is greased up, all good there. None of the joints have excessive play in them. I was hoping it would go away when I pulled the add-a-leafs out, no such luck. Drag link and track bar are parallel as best I can tell. Its not a major problem, just annoying. Any ideas?
my truck just developed the same problem any ideas what it is??
Sure sounds like a tie rod end ready to break. Any vibrations while going down the road? Possibly ball joints. Check left axle housing right behind inside u-bolt for any cracks. Also check center bushing for wear. Possible loose wheel bearings or bad u-joints in the axle shafts.
i have a slight vibration at my feet, its been vibrating for about a week now not crazy bad but i have unbalanced 35s so, but i jacked the truck up n no play at the TRES or the ball joints, i can just grab the steering links an roll em up n down with my hands, i greesed everything up still does it.
It got a little better when I removed the add-a-leaf, but never completely went away. I had all new steering linkage for the truck I was going to install but it got totaled in April so... problem solved for me lol.
ive checked over everything under the truck, all the TRES seem tight no play but i can roll them up in down no problem an i think thats the clunking noise so would that mean there worn out or????
Not worn out, but worn. That was the exact issue I had on my 96. If I pumped them full of grease it got better for a little while but never for very long. I had several shops look at it and more than one told me its a common problem on these trucks, especially when they've been lifted or leveled.
Ok so I should just replace the TRE's n steering linkages?
I wouldn't worry about it too much, but to each his own.
ya id like to replace it all, just having to hear the clunking is annoying. But i just priced out a whole new steering set up an i didnt realize it was gonna be that much to replace everything wow. Its about the same price for me to do a Rod End style steering i have that style done on my offroad truck, with rod ends on each end they are quarenteed not to wear out an become sloppy like a tie rod.
