Front D60 axle bearing number? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-01-2010, 07:38 AM Thread Starter
My front axle seals are shot. I can see some amount of play in the axle, so I guess the outer axle bearings are shot too.
I can't find the number of these bearings anywhere and the autoparts here are not listed for that.
Someone's having the correct bearing number (and seal number if you can) for my '96 F-350 4x4 5 speed.
Thanks!
1996 Ford F-350
7.3 Powerstroke, manual 5 speeds, 4x4, Crew Cab, Long Bed, Srw, 4.10 gears.
1995 Ford Taurus SHO
V6 3.0L DOHC Yamaha, manual 5 speeds, Eibach springs, Koni struts, Quaife ATB diff, Brembo brakes, K&N filter, solid motor mount, 2x Pionner PIAA 10" subs + JBL GTO 301.1II amp, Cobra CB radio and wilson antenna
crazy_canadian is offline
post #2 of 4 Old 07-01-2010, 07:58 AM
Nitro41's Avatar
here are the napa proformer part #'s for the inner bearing and race
PGB P387A---bearing
PGB P382A---race
NOS 14634---inner hub seal thats all i could find for the napa wheel seal. you might wanna check hat one out before you buy it.
should look like this
97 Single Cab F250 4x4 5 speed
Swapped D-60
Locked front and rear
160 sticks
Wildman Tunes
Hood Stack
OFE clutch
T500 HPOP
Linex rockers
35" MTR Kevlars
and a bunch more...
Nitro41 is offline
post #3 of 4 Old 07-03-2010, 09:46 AM
I priced front wheel bearings and seals, and diff. seals at both NAPA and local FORD dealer, found FORD dealer to actually be a few dollars cheaper.
95 F350 regular cab, 4WD, auto., straight pipe, everything else stock.
stroker95 is offline
post #4 of 4 Old 07-11-2010, 10:25 AM Thread Starter
Ok thanks! I called ford and they are a bit cheaper.
Can someone tell me is the axle bearing (behind the seal) is a needle bearing, or a cone shaped bearing (like a wheel bearing)
The autopart store and the dealer told me different things, but both didn't seemed to be sure.
1996 Ford F-350
