spindle nut torque specs? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-17-2009, 09:02 AM Thread Starter
Send a message via MSN to pwrstroke247
Question spindle nut torque specs?
I just got done doing brakes on the front of my truck. I was just wondering what the torque specs are for the spindle nut that holdes the whole rotor assembly on the spindle?? They were not that tight when I took them off but I want to make sure I dont over tighten them and ruin my wheel bearings.. Thank for the help, Justin ( my truck still has the factory auto hubs..)
1997 f250 4x4, 7.3l Powerstroke diesel, 174k, EC LB,
DIY Air Intake
5 inch MBRP exhaust W/ 6 inch tip.
FPR Shim
Edge Evolution Programmer
More mods to come
pwrstroke247 is offline
post #2 of 4 Old 12-17-2009, 07:44 PM
ryandamo's Avatar
the first one in should be torqued to 50 ft lbs (yes only 50) spin the wheel around to seat the bearing for a little bit then back it of a quarter turn, then put the lock washer in the middle, then the outter nut is 190 ft lbs
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #3 of 4 Old 12-18-2009, 09:03 PM Thread Starter
It only has one nut! Thats why I said my truck still has the AUTO HUBS..
DIY Air Intake
FPR Shim
More mods to come
post #4 of 4 Old 12-21-2009, 04:57 AM
ryandamo's Avatar
look at the chart at the bottom of this page then, perhaps it will make mre sense to you while looking at it, last one at the bottom... its for a dana 60 but the nuts/specs are the same for both axles
1996 Bronco/F-Series
ryandamo is offline
