Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
  #11 (permalink)
Old 06-22-2009, 02:11 PM
Dieseltorkin Dieseltorkin is offline
Send a message via Yahoo to Dieseltorkin
Just put a manual shut off valve in the supply line to the heater core, close it when you dont want heat and open it when you do
  #12 (permalink)
Old 06-22-2009, 02:36 PM
Tree Killer Tree Killer is offline
I have a manual shut off on both heater hoses, on my big truck. It helps keep alot of heat out of the cab,
  #13 (permalink)
Old 06-22-2009, 03:00 PM
johnstelly johnstelly is offline
Question
is this just a cable with it`s housing going to a control valve with a push/pull knob mounted on the inside the cab? so what i'm thinking i'll need is a manual valve with the right diameters (in and out) to splice into the hot coolant line on the engine side of the firewall to block off the inflow of hot coolant to the heater core that will (hopefully) eliminate extra heat inside. if so, would additional insulation on the undercarriage be necessary?
  #14 (permalink)
Old 06-22-2009, 03:08 PM
hey TREE KILLER, i do the same sometimes but usually i`am hired to save big ole trees at homes where the tree is a VERY IMPORTANT part of the landscape. What do u mean when u say both lines? the in and the out?
  #15 (permalink)
Old 06-22-2009, 03:09 PM
Yes he means both the supply and return line that connect to the heater core
  #16 (permalink)
Old 06-22-2009, 03:17 PM
They are a hand opperated valve. almost like a ball valve. The valve could go anywhere on the hose. If u did get a ball valve say from a hardware store u could probably solder short pieces of pipe, with the correct dia. to fit the hose. Just make sure tht all components will handle the heat. They have trees in Mexico?? ;]
  #17 (permalink)
Old 06-22-2009, 07:21 PM
THANKS TO ALL FOR THE INFO! and yes we do have trees in mexico; in fact one of the world`s largest with a circumference of over 160 feet in the state of Oxacca. it is a cypress
  #18 (permalink)
Old 06-22-2009, 07:24 PM
jamstoyz jamstoyz is offline
what about the simple heat deflector you put in your windshield? why dont you like using the ac?
  #19 (permalink)
Old 06-22-2009, 07:38 PM
i LOVE the ac and use it a lot but i don`t think it should be necessary when the weather is nice to cool. i also think that the ac lowers my MPG and acceleration plus the fact that i need a new hose since a charge only lasts a few months and costs me $25 to recharge the system.
  #20 (permalink)
Old 06-23-2009, 06:51 AM
symbols symbols is offline
Nonsense specialist
On a diesel running the A/C is not going to affect your MPG. My MPG's barely change when hauling an empty trailer.
The heater bypass is the easiest thing to do so I would try that first. If you still want it cooler then you can insulate the cab.
