Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 02-05-2007, 05:08 PM
tjazz_viking tjazz_viking is offline
7.3 Psd Drop In Mpg
Im wondering if one you guys have the same problem. Iwas getting 22mpg hwy in my 96 PSD and now im getting about 12 mpg hwy empty the truck has 80,000 miles on it. im about to try lucas oil fuel treatment to see that will bring it back up. im also going to try power source cetane booster to see that helps. this driving me crazy. this problem didnt happen over night . it slowly got worse and worse. does anyone had this problem that can help.
thanks.
Old 02-05-2007, 05:14 PM
pipelayerjdh pipelayerjdh is offline
MINI-MOD
How is it running now? My truck has dropped from 15 to about 13.5 in th past 3 years. Have you added a chip or tuner? I feel like mine is from degrading injectors. You may want to get it scanned for codes and get your injectors checked.
Old 02-05-2007, 05:22 PM
Jon
Tournaments Won: 1
Posts: n/a
It could be from any number of things.
If it goes gradually it is just something you need to get on top of. If it goes fast there is a bigger issue.
Old 02-05-2007, 05:23 PM
it seemed to be running fine but its just sucking the fuel down. i have no performance addons.
Old 02-10-2007, 12:11 AM
straycat straycat is offline
Hey tjazz, welcome to powerstroke, how did you make out with your millage issue. Were you doing the millage calculations by hand?
Gord.
Old 02-11-2007, 06:56 PM
Marty Marty is offline
International Threat
If you noticed it recently there are 2 major factors that I've seen IN my OWN truck (I've documented every drop of diesel that's gone in it for the past 30+ thousand miles).
Ultra Low Sulphur Diesel - less energy per unit volume then LSD = takes more fuel to go the same distance.
and
Winter Blend Fuel - less energy per unit volume compared to summer blend fuel. Once again = takes more fuel to go the same distance.
Old 02-12-2007, 11:53 AM
Gord.
well i started using lucas oil fuel treatment and it gained from 12 to 16.5 mpg (that hwy and city mixed)Im doing calulations by hand. i probily will pick up more if i go all hwy miles. hopfuly i find out soon if will do any better on the hwy. so far im impressed with the lucas oil fuel treatment. i would recomend it to everybody to try it. Next thing im going to try is the power source cetane booster (diesel clean w/cetane booster) to see if i gain some more. ill let you guys know what happens.
im sure glad i found this site . Im a big fan of the power stroke engines. Its the best truck i ever bought (w/ the power stroke).
Tony
Old 02-12-2007, 12:09 PM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
winter blend fuel and low sulfur fuel will both cause this concern ,like maintain
said
Old 02-12-2007, 11:53 PM
Glad to hear it's coming up, keep us posted on all the little goodies you try.
Gord.
Old 04-11-2007, 11:37 PM
Jeff_Northon Jeff_Northon is offline
Check for leaks. I had what looked like a small leak, about one drop every 5 seconds. Mileage went from 18 to 7.5MPG.
