Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 06-21-2009, 07:54 AM
Powerlift34 Powerlift34 is offline
Send a message via AIM to Powerlift34
Stuck in Myrtle beach
Aliright im on vacation in mytle beach, yesterday (our first day here) were driving and my gauges stop working other that the RPM gauge, and the throttle dont work, but the truck is still idleing. We check fuses and the something powertrain cont module, idle, and over drive control fuse keeps blowing, i just had it towed to a dealer and i have not a enough money for a dealer to fix it, i need some help quick, if anyone in Myrtle beach can help or SC that would be greatly appreciated. My number is 304-380-6282. We think a wire has grounded, but not for sure. Please help...
BTW. the truck is a 2000 model 7.3L PSD.
Old 06-21-2009, 08:09 AM
jcs jcs is offline
I'm not sure whats wrong it does sound like a wire is grounding out but at the very least here is a bump to keep you at the top
Old 06-21-2009, 08:21 AM
nccatfan nccatfan is offline
Send a message via AIM to nccatfan
Worst case scenario would be the PCM gone bad (they do occasionally short internally). I'd hunt wires for a few hours before I replaced that tho.
Old 06-21-2009, 08:49 AM
CHUCK CHUCK is offline
Lifetime member
bumping you back to the top........
Old 06-21-2009, 09:14 AM
mudrunninpig mudrunninpig is offline
D80 Axle Snapper
another bump..............
Old 06-21-2009, 09:17 AM
7004 7004 is offline
I had the same thing in my wifes 2002 ex it ended up a bad wire or ground in the stearing colloum
Old 06-21-2009, 09:20 AM
97 golden stroker 97 golden stroker is offline
Did the dealer find the problem or not even look at it? if they found the problem then they have to tell you if they charge for diag. and if they have not looked at it at all you should try to find a small shop around there and see if they can find the problem. good luck man
Old 06-21-2009, 09:23 AM
Rodslinger Rodslinger is offline
Gun Nut
Keep it at the top.....
Has the dealership looked at it yet?
ETA - do you have any aftermarket parts on her?
ETA #2 - just saw your sig - yeah you have a couple.
Damn I'm no Tech but it sure sounds like a wire is fubar and blowing that fuse.
Old 06-21-2009, 09:25 AM
bump bump ...
Old 06-21-2009, 09:44 AM
bump bump..
