Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 01-23-2007, 05:40 PM
powerjunky powerjunky is offline
diesel adddict
brake lights
Rear brake lights are not working. The one on the cab is working. I have checked every fuse, relay and traced wires. Trailer brake controler is not working plugged, I have unplugged and plugged it in no change. Ford told me to set comuter back to stock, I have a SCT. He said that the computer might be confused, did that no change(disconected batteries for 1/2 hour after setting back to stock. Any other ideas would be apprciated.
Old 01-23-2007, 05:55 PM
mschn99 mschn99 is offline
Banished
I promise im not trying to sound like a smart alek...but did you check the bulbs? sometimes they dont look burnt out when they are....and ive seen people physically inspect them and not see a burnt looking bulb and go down the wrong road...and this would be even easier to do with two out..if you assumed it wouldnt be the bulbs then.....
The brake lights dont run through a module. They go only through the multifunction (turn signal) switch. they use the same circuets as your blinkers...so if your blinkers work you know the wires are good. If the brake lamp switch ont he brake pedal rod tests good..i would look at replacing the MF switch....
Old 01-23-2007, 06:00 PM
pipelayerjdh pipelayerjdh is offline
MINI-MOD
I recently had problem with my high beams on a '99. Found out it was a bad connection on the multi-function switch. I removed the switch and cleaned the connectors and they work great.
Hope this helps!
Old 01-23-2007, 06:11 PM
diesel adddict
Yes I checked the bulbs.(no insult taken) where is the multi funtion switch
Old 01-25-2007, 12:05 PM
straycat straycat is offline
Moderator
Also known as the turn sig lever, It connects to almost everything, including your wallet on ocassion hahaha.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
