Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 04-25-2009, 05:30 PM
traumajunkie21 traumajunkie21 is offline
Twisted Wheels, INC
Stack Install
Ok so im installing stacks had it all done and took the stacks off to make adjustments, first one went back in fine. Second one wont go in .... i need like a tailpipe expander but cant find one big enough.....
any ideas????
Old 04-25-2009, 09:28 PM
diesel_19 diesel_19 is offline
stack wont slide back in?if thats the case get a hammer and bend the top of the 90 out so it will
Old 04-26-2009, 12:06 AM
XtReMe FrOm HeLL XtReMe FrOm HeLL is offline
yeah what he said, take a hammer and make the opening a little bigger, then once you tighten the clamps it would bring it back in...
Old 04-26-2009, 12:22 AM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
+ 1 more to what he said
Old 04-26-2009, 04:51 AM
Twisted Wheels, INC
I tried..maybe not hard enough, gave up after two hours. I beat the livving daylights out of that pipe and still didnt fit.
Old 04-26-2009, 05:35 AM
Southpaw Southpaw is offline
1/20/2013
You said it all fit the first time, right?
What happened to it after you took it off?
Old 04-26-2009, 10:21 AM
Twisted Wheels, INC
its bent from the clamps
Old 06-28-2009, 08:35 PM
joeficsit joeficsit is offline
i did a search on "expander" and this was the only thread that showed up. Hopefully the problem was solved by now, but i figured if anyone ran a similar search, it would be better to just continue with this one rather than start a new one.
that being said. i got a used exhaust for a song and also need an expander large enough for these diesel exhausts. the reason is that although i managed to get the slip joints apart, you can see where they are slightly deformed from the previous clamping. I would like to re-true the opening of the slip joints.
so... does anybody know where i can get a LARGE tailpipe or tube expander?
Old 06-29-2009, 08:44 AM
heard farms heard farms is offline
If you have a local Heavy truck shop that does exhaust they should have what you need to reform your exhaust.
Old 06-29-2009, 08:50 AM
Matt P Matt P is offline
a truck
yeah your just gonna have to beat on it with a hammer till it fits, Ive had to do that with a stack kit I installed, its just a pain, you really dont want to tighten those clamps til you have it right where you want it
