Water pump pulley - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 5 Old 07-26-2014, 10:50 AM Thread Starter
Water pump pulley
Help!! My water pump pulley is broken. The pulley section broke apart from the center section that bolts to the water pump. I can't find a way to hold the water pump still so I can remove the fan and replace the pulley. Any advice would be appreciated. First time on this forum. I think I attached a photo.
Band geek is offline
post #2 of 5 Old 07-26-2014, 03:51 PM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
First, I have No Idea if this would work, but,,, could you remove the heater hose (or even the nipple itself) at the bottom of your pic, and jam a chisel into the impeller?
NoRalPh is offline
post #3 of 5 Old 07-27-2014, 09:09 AM Thread Starter
I took the water pump and fan off as one unit and I used my grinder and sawzaw to cut the pulley. Now I can't get the fan off. I rented the tool and put so much pressure on it that it bent the tool. I think there might be a thread about fan removal.
post #4 of 5 Old 07-27-2014, 09:45 AM
Rodslinger's B1TCH
steve604 is offline
post #5 of 5 Old 08-26-2014, 07:35 PM
When my pulley broke I was able to use an air chisel on the corner of the nut to knock the fan loose.
Early '99 S-Cab 7.3l tuned by PHP; 2003 Excursion 6.0l PHP Atlas 40
colekym is offline
