05 powerstroke shaking at idle!! - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 6 Old 07-08-2014, 08:45 PM Thread Starter
I own a 05 powerstroke with 198k miles on it! Today I started up my truck and it began to shake(not violently)but shoke the whole truck a good amount, the engine was already at operating temp so I reved it up, (thought it was just a fuel thing). I have no idea wat could cause this! Once I begin to drive it will smooth out and go away! If I'm at red light for more than 15-20 seconds it will start to shake again! I would really appreciate someone's knowledge in this!
Arp head studs
Powermaxx turbo
Egr delete and upgraded oil cooler
Upgraded fuel regulator
AirRaid direct cold air intake
All brand new gaskets all the way around!
4" magnaflow turbo back straight pipe
Dark1244 is offline
post #2 of 6 Old 07-08-2014, 09:02 PM
Quoted: 865 Post(s)
Feedback Score: 3 reviews
More than likely its a sticky injector. But I'm sure some of the more knowledgeable 6.0 peeps will chime in.
Corey@CNCFAB is offline
post #3 of 6 Old 07-09-2014, 05:33 AM Thread Starter
If it were a sticky injector, what is the best way for it to start properly working again
Arp head studs
Powermaxx turbo
Dark1244 is offline
post #4 of 6 Old 07-09-2014, 05:54 AM
dannanw's Avatar
Quoted: 66 Post(s)
Garage
Remove and replace is the only true way, but rev-x is a common additive....
oh and making 4 threads of the same issue aint the way to get help, its just annoying.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #5 of 6 Old 07-09-2014, 10:43 AM
Quoted: 865 Post(s)
What he said ^^^^^^ If your interested OP, I carry stock replacement 6.0 injectors.
post #6 of 6 Old 07-31-2014, 10:19 AM
If you could borrow a cut out box it would work great for trying to narrow that one down.
Cut out or break out box, is basically a wiring harness going between the 9 pin connector on the valve covers, with switches wired inline to shut off individual injectors.
Sounds like injector issues or IPR to me, maybe even simple like o rings. Have you observed oil discharge from the injectors with the valve covers off?
Performance Parts & Products for Ford Powerstroke Diesel Trucks
(Dodge, GM & all other diesel vehicles)
Lowest Price Guarantee - *Free Shipping - Free Diesel Advice from Factory Trained Techs
###### SPECIAL PURCHASE NOTICE #####
Black Friday Pre-Sale on Edge Products - Prices Too Low to Advertise - PM for Special Powerstroke.org Discount
OCDiesel is offline
