99 7.3 major problems - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 8 Old 07-05-2014, 05:53 AM Thread Starter
I have a early 99 f350 diesel.. I been have a problem with the truck running and dieing but idle normal but rough as well .. I can drive my truck 1 to 5 mins at times and misses smokes runs like **** then dies .. half to let it sit at least 20 mins before start up.. When it does start I gotta sit there for a few mins clearing it out and will only last a few miles and gotta repeat all the step to get moving again .. The only time I can drive it a Lil further is in the morning. . I had a code come up on the snap on computer was combustion balance fault .. on number 8 and 3 .. I replaced 8 and 3 injectors I also tested the wiring gasket fuel filter .. fuel pump and the ipc or whatever the thing is called to the lower right of the filter ..
jules083 is offline
post #2 of 8 Old 07-05-2014, 06:02 AM
Quoted: 7 Post(s)
For future reference, replacing injectors based on a contribution balance fault code, especially on cylinders 3 & 8 is most often a waste of money. Any cam position sensor other than the OEM black one will cause codes for those cylinders, and it's usually not accurate.
I assume that snap-on scanner will let you monitor live data. Set it up to monitor ICP, IPR duty cycle and RPM while cranking, and (hopefully) when it starts. Do you have a mechanical fuel pressure gauge you can install? If you leave it idling, will it continue to idle fine and not have a problem until you start driving? Were there any other codes present, like maybe P1211?
Pikachu is offline
post #3 of 8 Old 07-05-2014, 08:56 AM Thread Starter
I don't know how to do the live data on the scanner my buddy does but he's not home and I do not have a Guage on my fuel and no tire valve on the motor to check that ..and yes it will Idel fine for hrs in till I pull out and it will miss and die after a mile or so
jules083 is offline
post #4 of 8 Old 07-05-2014, 08:57 AM Thread Starter
Sorry no other codes
jules083 is offline
post #5 of 8 Old 07-05-2014, 09:36 AM
Quoted: 7 Post(s)
On the surface, it sounds like a fuel starvation problem. There are other things that could cause those symptoms, but I'd start by checking fuel pressure. At idle the pressure should be roughly in the 55-65 range, and should stay pretty close to that under load. There is a test port on each head with 1/8" NPT threads, and there's a port on the filter housing, low on the right (passenger) side near where the fuel lines exit to the heads. That port takes a #4 o-ring boss fitting.
While you're under the hood, check to make sure the solenoid and spacer are still secure on the IPR and the nut that holds them is tight. You can also disconnect the wiring connector on the ICP sensor and take it for a drive to see if there's an improvement.
Pikachu is offline
post #6 of 8 Old 07-05-2014, 10:14 AM Thread Starter
OK thanks ill get back to u later on
jules083 is offline
post #7 of 8 Old 07-05-2014, 12:21 PM Thread Starter
OK put in new cam sensor let it Idel for about a hr drive for 5 mins and started back firing and lost its power again ..
jules083 is offline
post #8 of 8 Old 07-07-2014, 09:46 AM Thread Starter
The socks in tank where clogged 100% thanks for your help
jules083 is offline
