99 7.3 major problems - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 3 Old 07-04-2014, 07:26 PM Thread Starter
I have a early 99 f350 diesel.. I been have a problem with the truck running and dieing but idle normal but rough as well .. I can drive my truck 1 to 5 mins at times and misses smokes runs like **** then dies .. half to let it sit at least 20 mins before start up.. When it does start I gotta sit there for a few mins clearing it out and will only last a few miles and gotta repeat all the step to get moving again .. The only time I can drive it a Lil further is in the morning. . I had a code come up on the snap on computer was combustion balance fault .. on number 8 and 3 .. I replaced 8 and 3 injectors I also tested the wiring gasket fuel filter .. fuel pump and the ipc or whatever the thing is called to the lower right of the filter ..
jules083 is offline
post #2 of 3 Old 07-04-2014, 08:15 PM
Rodslinger's B1TCH
your oil level is ok right?
how did you test the ICP?
your fuel level is above 1/4?
steve604 is offline
post #3 of 3 Old 07-05-2014, 04:54 AM Thread Starter
Yes sir steve all that is good my buddy texted the icp after I got a new on to make sure the wire where ok
jules083 is offline
