Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 12-21-2008, 01:48 PM
dieseldan2005 dieseldan2005 is offline
If it aint a CAT itsa DOG
I need electrical help
I keep blowing my #38 fuse for my trailer running lights. So i am assuming the plug needs to be replaced. It does it on both of my trailers so i'm pretty sure its not in the trailers. I can't find a factory replacement 7+4 pin harness. I can only find the 7 pin alone. Anyone know where i can get one? I need one fast cause i'm going on a trip soon and will be pulling a trailer. Also I called Ford and they want 170 bucks for it. No way man! There has to be a cheaper place. Any help would be great. Thanks guys.
Old 12-21-2008, 02:03 PM
come on guys
Old 12-21-2008, 05:01 PM
elibenson elibenson is offline
I thought I found a 7+4 connector at Tractor Supply Co. If you were closer, I would rip mine out and give to you. I hate those POS 7pin plugs. Don't stay connected for anything. All my trailers use 6-pin and they actually work. Unfortunately I haven't had time to wire the truck with a 6pin plug yet, so I have to use a POS adapter. Don't even get me started about adapters...
Old 12-22-2008, 04:00 AM
Dave Dave is online now
Your Whambulance is here
Northern Tool should have an aftermarket one. Otherwise check Boyer ford. They probably have the factory one
Old 12-22-2008, 03:46 PM
Yeah my dealer has one but it is 170 bucks. I think what i am gonna do is put a new 7 pin on and then get the 7/4 adapter to plug into it. It is about half the price.
Old 12-22-2008, 04:02 PM
jamstoyz jamstoyz is offline
maybe try uhaul? or take the plug apart and redo the connections. im sure they are corroded. there is electrical stuff called no locs and its for corrosion. i use it all the time at work cause im a electrician.
