Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 12-13-2008, 12:19 PM
hc speed hc speed is offline
runnin on 4
96 f350 is only runnin on the drivers bank with the engine running you can un plug the harness to the passengers side and no change in rpm but if you un plug either of the drivers side it dies any body know why???
Old 12-13-2008, 12:47 PM
alabamafrog alabamafrog is offline
Powerstroke Techie
Most likely the UVC (under valve cover harness) is fried or the plugs in the valve cover gaskets are fried. Relatively easy fix, you can buy the whole thing or replace the pins in the plugs. Only other thing I can think of is possibly something wrong with the IDM.
Old 12-13-2008, 12:50 PM
thanx frog but what the hell is an IDM and are the uvc harness available aftermarket
Old 12-13-2008, 12:57 PM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
i agree , the reason the harness gets burnt up is the glow plugs are goin bad , high resistance from the glow plugs causes heat , then the heat damages the wiring , better replace the glow plugs , or you will be doin it again
Old 12-13-2008, 01:26 PM
Powerstroke Techie
I recommend replacing the glow plugs with a good quality plug like the Bosch Durotherm, cheap plugs can and will stick in the heads and break off the next time you try to get them out causing you to have to remove the head.
IDM (Injector Driver Module) basically a box that makes around 110 volts DC power to fire the injectors, its unlikely that this is your problem because when it goes you usually loose everything but I have heard of at least 1 case where it went bad and he still had one side.
The plug in the valve cover gasket is know for problems, there is a lot of juice flowing through there when the plugs are on and it tends to melt things.
Old 12-13-2008, 01:51 PM
you guys are genius I suppose the uvc harness is wired in series the front one had a terminal melted and the rear would not fire i moved the rear to the front and go it to fire 6 cyls , was replacing the gps anyway I bought autolite 1111 s hope thry will be ok where should i try to find this new harness any part #s thanks again
Old 12-13-2008, 05:55 PM
Powerstroke Techie
I got my new harnesses pretty cheap on ebay. Also might check with International or some online parts places.
Old 12-14-2008, 10:40 AM
well I am still after it , got a uvc harness from a friend , and got her back together now I can crank it and it runs great for about 2 secs and then drops the right bank and the engine light comes on I can shut it off and restart it same thing every time I don't have a scanner is there a short cut to read the codes like a GM?
Old 12-14-2008, 11:19 AM
Powerstroke Techie
Nope, no short cuts, you got to have a code reader and any old reader wont work, it has to be one that is compatible with the 7.3, I had a regular OBDII reader and it wouldn't see the codes in my truck. Try double checking all of your wiring and connectors and internal pins.
Old 12-14-2008, 12:53 PM
bama frog I can't thank you enough for your help , just pluged in my buddies snap on tester got 2 codes p04700-exhaust pressure sebsor ckt fault and p0603 internal control module KAM error , have you ever seen this before ?
