Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 12-08-2008, 09:40 PM
harleycjm1 harleycjm1 is offline
Angry electrical nightmare
ok, i replaced my starter cause it went bad, my batteries also had a few bad cells, now my truck is reading 10-11v on my tuners screen, is my alternator going to or is there another electrical issue that could be causing all this, i am going broke fixing this thing, all this in 4 days!! HELP ME IF YOU CAN!!!
Old 12-08-2008, 09:48 PM
kinghawg98 kinghawg98 is offline
i feel your pain bro.
I spend about 2k in a week and a half........all when my business slows to a crawl. Good times!
You could have just a loose connection, or a bad alt..check connections.
alternator is a cool 340 bucks.
Old 12-09-2008, 07:38 AM
Hardline Hardline is offline
Have you had your electrical system diagnosed? I would have to say that the batteries, starter, and alternator all going bad in 1 week is kinda impossible. I would have the alternator tested. If you have already changed the batteries and starter than no need in having to worry about that it is already water under the bridge. Get it tested so you are not wasting your money.JJ
Old 12-09-2008, 07:49 AM
symbols symbols is offline
Nonsense specialist
You need to check it before you start throwing parts at it. If you don't know how we can help you.
Old 12-09-2008, 09:04 AM
i had the alt checked, it was putting out 65 amp max, i replaced this now.... lets see how long this lasts
Old 12-09-2008, 09:13 AM
Nonsense specialist
Those auto parts stores tests are not 100%. have you checked the charging voltage at the batteries under load?
Old 12-09-2008, 09:15 AM
i am now reading 13.4 under load for voltage insead of 10.1-9.8
Old 12-09-2008, 09:20 AM
Nonsense specialist
Ok. Was that on the truck or on the bench? If was on the bench make sure that you check it on the truck. If that is the voltage on the truck then you should be fine. Just to be clear when I say under load that means you turn everything in your truck that you can on from windshield wipers to door lights.
Old 12-09-2008, 09:29 AM
its what my tuner said voltage was whn everything was on, including the light bar and siren, which the neighbors really ejoyed!!!
Old 12-09-2008, 09:40 AM
lifewitlooie lifewitlooie is offline
COLLEGE KID
Send a message via AIM to lifewitlooie
at a reputable auto repair facility you can get a whole starting system diagnostic run.
for pretty cheap ususally.. i think fifty bux
