Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 12-07-2008, 10:48 AM
shiplong shiplong is offline
Truck broke Down and I'm nearly broke too
Hello all,
Friday night my 03 F250 6.0 broke down on the interstate and had to be towed to a dealership. The engine had no power to accelerate, it was if it was starved for fuel. I mashed the accelerator to the floor and the RPM's were only about 1800, then slowly went down and I pulled into the emergency lane. The truck just slowly died right there and would not restart.
The tow guy said that it sounded like an injector problem; he said that if I ever let my tank get low (below 1/4) that it was pulling in water and this is what has destroyed my injectors.
Yesterday, I went and topped it off with 10 gallons of fresh fuel and cranked it up, then drained the water seperator a few times (I always drain it when the light comes on). It ran fine for a minute (I could rev it up above 2000 RPM), then I let off to idle, then mashed it again and it only hit 1700 and slowly dropped, so the low RPM thing is repeatable, but not consistent.
Any ideas?
Old 12-07-2008, 10:53 AM
RRonning1984 RRonning1984 is offline
Heavy Equipment 911
Maybe the HPOP is dying. I'm not an expert so DO NOT put stock in that! Someone will know though!
Old 12-07-2008, 11:01 AM
nsrchofpwr nsrchofpwr is offline
lifetime member
that what my symptoms were when the HPOP died.
Old 12-07-2008, 11:11 AM
2005F250 2005F250 is offline
HPOP = High Pressure Oil Pump. And the HPOP is what causes the injectors to fire and if the HPOP fails then the injectors won't work.
Old 12-07-2008, 11:14 AM
shu873 shu873 is online now
hillbilly keyboard racer
where did this happen?
Old 12-07-2008, 11:15 AM
Is the HPOP and expensive part? Is it a job for a pro? How much do you think the dealer would charge to replace it?
Old 12-07-2008, 11:16 AM
Throttle pedal could be the culprit.
Old 12-07-2008, 11:17 AM
Heavy Equipment 911
Yea, I feel smarter.
Nashville, TN on I-40 at the on ramp. My truck never got up to highway speed and it just died on the top of the ramp.
Old 12-07-2008, 11:18 AM
Heavy Equipment 911
A new one from the dealer will be expensive but you can find good deals if you shop around. What do you consider expensive is the question?
