2006 won't start without starting fluid - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 6 Old 04-11-2014, 03:39 PM Thread Starter
chancelor's Avatar
Had a fuel issue about a month ago now it only wants to start with starting fluid. After it starts it's sluggish. It's not throwing any engine codes currently and the fuel filters are new. Any suggestions?
2006 F350 4X4 Lariat... Just getting started with this one... afe air intake, edge juice platinum with attitude, coolant filter kit, high idle switch added, blue spring conversion Fan clutch switch, daystar leveling kit, zoodad, a few extra lights, custom gooseneck hitch and air bags on the rear
chancelor is offline
post #2 of 6 Old 04-12-2014, 08:47 AM Thread Starter
chancelor's Avatar
Need help guys anyone have any ideas
post #3 of 6 Old 04-12-2014, 05:20 PM
midnite rider's Avatar
Quoted: 285 Post(s)
can u monitor your fuel pressure, sounds like fuel pump craped out
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #4 of 6 Old 04-12-2014, 05:32 PM
shenanigans
junior125's Avatar
Quoted: 1430 Post(s)
Garage
also do you piston rings and cylinder walls a favor and stop using starting fluid, can you check for any codes for glow plugs? will the truck start if the block heater has been plugged in?
Mike
2005 CCSB F250 4X4
O-ringed with H-11's, Irate T4, BW S363SX-E, Holders 175/30%, TSD Tunes, No Limit Intake, CSF Intercooler, BPD Remote Oil Cooler, BPD water pump, 7.3 Fan Adapter, BD Diesel Manifolds, 6.7 Pump, Driven Diesel RR, Built Trans w/ PI converter, Derale Deep Pan, Traction bars, AirLift Helper Bags
junior125 is online now
post #5 of 6 Old 04-12-2014, 06:39 PM Thread Starter
chancelor's Avatar
Ya I only used it once and not doing it any more this engine only has 30k miles on the longblock
post #6 of 6 Old 04-12-2014, 06:42 PM
shenanigans
junior125's Avatar
Garage
also check FICM volts as well, how old are your batteries, and have they been tested?
Mike
2005 CCSB F250 4X4
