7.3 Thermostat Housing Bolt rounded off - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 4 Old 04-10-2014, 09:28 AM Thread Starter
03ranger30's Avatar
Can't seem to get this damn thing off. The other two came off easily compared to this one. Broke both my 5/16ths sockets and rounded the bolt off using the wrench. Tried grinding a slot in the middle to use a screw driver to no success.
I don't want to break the bolt off or anything because I don't have an extractor.
Any ideas? I would like to get this done today so the truck doesn't sit.
Thanks!
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #2 of 4 Old 04-10-2014, 09:49 AM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 350 Post(s)
A bolt extractor works very well in this type of situation.
7.3 Thermostat Housing Bolt rounded off-imageuploadedbyautoguide1397148510.055717.jpg
I had some rounded off ujoint cap screws and this bad boy got them all out.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #3 of 4 Old 04-10-2014, 10:11 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Be verrrrrry careful when you do because you will probably break the head off if its in that good. I broke two off on my OBS and boy was that a B$#$%@#$$#!@@$ because its so close to the HPOP reservoir you cant drill straight very easily. I ended up having to African engineer it with 2 new holes in the water pump and housing
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #4 of 4 Old 04-10-2014, 01:07 PM Thread Starter
03ranger30's Avatar
Ended up just taking a similar sized metric (8mm) and using some force and it came right off. Thanks for the help though!
Charlie
