7.3 power stroke problem I'm lost! - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 14 Old 04-03-2014, 06:58 PM Thread Starter
Exclamation 7.3 power stroke problem I'm lost!
Hey guys I just got an 02 7.3 powerstroke a few. Ugh ya ago he told me it needed a idm but after I went and looked and finally got the truck to crank it ran great and he really didn't no what he was talkin about much like myself. I have replaced the ipc and cps but truck still wants to suddenly die while driving and another trick it started a little whole ago is it will now idle but won't hardly let me rev it just sputters. What's rong woth my truck?! Help plz
Buff is offline
post #2 of 14 Old 04-03-2014, 07:39 PM
White Noise
AU7POINT3's Avatar
Quoted: 2 Post(s)
WELCOME TO THE ORG !!! Clean oil? Right oil at proper level? Clean fuel and filter? Water in fuel? Proper fuel pressure / good strong pump? Loose or chaffed valve cover / injector wiring harness? Loose or chaffed Injector Driver Module harness (IDM inside driver fender well)? Good luck...
2002 F-250 LARIAT CCSB 7.3 AUTO 4X4 261,XXX
2004 EXPLORER XLT 4.0 AUTO 2WD 130,XXX
1966 MUSTANG COUPE 289 4 brl V8
IN-LAWS...
2004 EXPLORER SPORT TRAC 4.0 4X2 100,XXX
2004 F-250 RCLB 6.0 AUTO 4X2 38X,XXX
2005 F-250 RCLB 6.0 AUTO 4x2 36X,XXX
SOLD... 3 RANGERS, 3 F-150s, 3 F-250s, 96 COUGAR 4.6, 99 EXPEDITION 5.4, 65 66 AND 69 MUSTANGS
RE-ASSIGNED... MULTIPLE FORD POLICE INTERCEPTORS
AU7POINT3 is offline
The Following User Says Thank You to AU7POINT3 For This Useful Post:
Buff (04-05-2014)
post #3 of 14 Old 04-04-2014, 03:28 PM Thread Starter
Could be the wiring under valve cover I guess i don't no why I put the new sensor in and it caused this tho
Buff is offline
post #4 of 14 Old 04-04-2014, 03:46 PM
White Noise
AU7POINT3's Avatar
Quoted: 2 Post(s)
may not be the new sensor causing it, but something else wiggled loose along the way.
Buff (04-05-2014)
post #5 of 14 Old 04-04-2014, 03:47 PM
White Noise
AU7POINT3's Avatar
Quoted: 2 Post(s)
Not likely the new sensor, but something else wiggled loose or chaffed along the way.
IN-LAWS...
post #6 of 14 Old 04-05-2014, 06:35 AM Thread Starter
I agree after continuously messing with it I got it running a and drove 15 miles no issues but left it in the driveway idling suddenly once again it's like ilyou cut the key truck started right back up tho. I do notice when it is running it doesn't sound quite right tho. I left it sitting for awhile and came back started it and same thing sputters and sputters until I cut it off and start it 20 times and the engine gets warm then it seems to rub decent still doesn't sound correct tho. I'm leaning twards injector harnesses what do you all think?? Thanks for the help!
Buff is offline
post #7 of 14 Old 04-06-2014, 12:40 PM
midnite rider's Avatar
Quoted: 285 Post(s)
is there a performance chip in your truck. if so unplug it from the pcm. ?
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #8 of 14 Old 04-06-2014, 05:17 PM Thread Starter
I've already done that man it has a TS THATS it. I don't no what to do in thinkin possible and idm now I wish I new someone that had one I could barrow to rule that out
Buff is offline
post #9 of 14 Old 04-06-2014, 05:51 PM
E99F350Stroker's Avatar
Do you know any one who has a diagnostic scanner?
Jordan
*Sold* Early 99 F-350 dually 4x4 6spd 7.3
*Sold 2000 F-250 4x4 ATS auto 7.3
1996 Dodge 2500 4x4 speed, 12 valve cummins, 283000, stock
E99F350Stroker is offline
post #10 of 14 Old 04-06-2014, 06:03 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 491 Post(s)
If guy you purchased from said it needed an IDM then maybe it does.
You can get one on ebay for 130$ exchanged from a place down here in FL
Sent from AutoGuide.com App
@loxdce
LoxDiesel is online now
Tags
ipr icp , missing , rev , stalling while driving , won't start
