Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 12-04-2006, 07:00 PM
AKsledder AKsledder is offline
Unhappy 7.3 kind of starts
I didn't want to jack Quadracers post but I am having about the same problem. Temperatures dropped here in Utah but the truck had been running fine. Got in it for work this morning and the batteries were dead. Jumped it, got it going and let it warm up for about 5 minutes, so far so good. Got down the street about 100 yards and that is all she wrote. I towed it back to the yard, plugged it in, put the battery charger on it and let it sit for the day. The batteries were kind of old so put two new interstates in. Cranks fine but just won't quite start, chugs and smokes but no run. I replaced the glow plug relay, and checked power to it all good. I put some power service in the filter bowl still no start. Any ideas would be greatly appreciated.
So long story short-- 2 new batteries, new glow plug relay, power going to relay, power service in filter bowl, temps out side 20 deg
Thanks for any help
Old 12-04-2006, 07:04 PM
mschn99 mschn99 is offline
any codes? does the tach work while cranking? have you checked all your fuses carefully?
Old 12-04-2006, 07:07 PM
Yeah, tach comes up, I even cranked it long enough that the oil pressure comes up.
Old 12-04-2006, 07:09 PM
Oh sorry I don't have a scanner, but no check engine light, unless the engine needs to be running to get a light
Old 12-04-2006, 07:11 PM
have it scanned at a parts house and check all your fuses carefully first
Old 12-04-2006, 07:38 PM
sorry, since it doesn't move I was hoping for an idea I could take care of at my house. I have power going to the relays, and I can hear them clicking
Old 12-04-2006, 07:48 PM
Clay Henry Clay Henry is offline
Sooner Powerstroker Mod
Thanks for any help
How about your CPS? Is it original or new??
Change it if it's original.
Old 12-04-2006, 07:51 PM
Not original, but 5 years old, sounds like a good idea, I will give it a look see in the morning, Thank you much, Hope I didn't change the relay for nothing
Old 12-04-2006, 08:00 PM
Good luck and tell us what happens whith that!
Old 12-04-2006, 08:03 PM
Wink
Nooo, Thank you and will let you know.
