6.0 stuttering and smoke - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 28 Old 03-15-2014, 05:28 PM Thread Starter
2004 6.0 is stuttering upon accelerating at stop lights. Or when in overdrive and starting up a hill, or under a load hauling a trailer etc. It's sounds like the EGR again, but I've cleaned it again, put on new O-rings. Last time I cleaned it, it wasn't that dirty and it wasn't stuck. But I cleaned again and reinstalled. Also, it might be me, but it seems as though it gets worse when fuel is low. If it's not EGR what else can it be? Also it smokes a little when this happens as well. Most of the time it's black smoke, but it has been white also. Just a big puff an then I'm good to go.
2004 F-250 4x4 6.0L
Bully Dog Dual 4" Exhaust
All Aluminum Radiator
Bullet Proof FICM
techno101 is offline
post #2 of 28 Old 03-15-2014, 10:48 PM
if you pull on the pintle of the egr, it should spring right back into its bore. sometimes the shaft of the pintle binds internally = bad egr valve. Your problem sounds like a fuel pressure or faulty injector(s)
Scumbag is offline
post #3 of 28 Old 03-16-2014, 09:09 AM Thread Starter
I've heard that the EGR cooler can become clogged as well. Would this cause the engine to bog down also?
2004 F-250 4x4 6.0L
Bullet Proof FICM
post #4 of 28 Old 03-16-2014, 09:31 AM
What can happen is carbon builds up in the egr cooler/intake mainfold, and the carbon can eventually flake off and momentarily hang a valve. That is something that would happen intermittently, and would be impossible to duplicate at will, and would probably happen once /week-month. If your truck does it all the time, i would suspect fuel injector/fuel pressure/FICM MPower. If pump whines, it would be worth pulling the filter from the framerail pump and seeing if the outer-layer has "wrinkles" in it, causing a restriction.
Scumbag is offline
post #5 of 28 Old 03-16-2014, 11:04 AM Thread Starter
I change fuel filters often, but I can pull it out and check. Truck has 161 K miles, how long do injectors normally last? And how would one determine which one is faulty?
2004 F-250 4x4 6.0L
Bullet Proof FICM
post #6 of 28 Old 03-16-2014, 11:08 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
You have an injector going out.
See if you can get a code reader on there ASAP.
I'd limit your driving too...
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #7 of 28 Old 03-16-2014, 11:11 AM Thread Starter
So injector failure... Will a code reader tell which one is going out?? And can you accelerate out of a bad injector? It's only a low RPMs when this happens.
2004 F-250 4x4 6.0L
Bullet Proof FICM
post #8 of 28 Old 03-16-2014, 11:14 AM
dfuzz78's Avatar
Yes and Yes, initially.
You'll have cylinder contribution codes in whatever cylinder it is.
Denis "Lt. Sled"
dfuzz78 is offline
post #9 of 28 Old 03-16-2014, 11:16 AM Thread Starter
Ok, let me see if I can get ahold of one. I'll let you know what I find out.
2004 F-250 4x4 6.0L
Bullet Proof FICM
post #10 of 28 Old 03-16-2014, 11:19 AM
dfuzz78's Avatar
Auto parts stores usually check codes for free...
I'm telling you this from experience, I had the same thing happen to mine right after I bought it.
I hadn't even made a payment on it yet!
Denis "Lt. Sled"
dfuzz78 is offline
