Chunks of plastic in engine oil - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 17 Old 03-14-2014, 02:24 PM Thread Starter
Buddy called me over to look at his truck because of a hard start and very rough idle.
He started it for me and when it fired is sounded like it was running on two cylinders. I pulled the dipstick and this is what I found.
Looks like the dipstick plastic was breaking off and falling down the tube into the oil. What do you guys think. I told him he probably damaged multiple injectors and maybe the HPOP.
ID:	257585   Click image for larger version
07 F250 CCSB Banks Ram Air, Blue Spring Mod, High Idle Mod, Sinister Coolant Filter, 4 Inch Turbo Back Exhaust, Bulletproof diesel FICM, DC power 185amp alternator
burnindiesel is offline
post #2 of 17 Old 03-14-2014, 02:31 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
At the very least id say he needs to replace the oil cooler screen and the IPR screen as well. That's if he is lucky!
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 17 Old 03-14-2014, 02:37 PM Thread Starter
I have no idea why the dip stick would have disintegrated like that. anyone ever seen that? The dip stick on my 07 is different.
post #4 of 17 Old 03-14-2014, 02:41 PM Thread Starter
so its going to be a little more work than changing the oil and dipstick out right.
post #5 of 17 Old 03-14-2014, 03:19 PM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
All we know about your buddies truck..is that its a truck and it appears to have been neglected. Fill us in some?
Please
You could save the life of a sick child
NYC F-350 is offline
post #6 of 17 Old 03-14-2014, 03:34 PM
Quoted: 8 Post(s)
Plus it's running rough… which makes me believe the HPOP is plugged up somewhere.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #7 of 17 Old 03-14-2014, 05:46 PM Thread Starter
Sorry its a 05 f250 CCSB 6.0. 60k
post #8 of 17 Old 03-14-2014, 06:20 PM Thread Starter
Found the problem!!!! He had striped out the fuel pump drain plug changing the fuel filters himself. When he put the new part on he didn't connect the fuel pump electrical connection all the way on. Drained the oil and replaced the filter using rotella t-6 and a motorcraft filter. bam fired right up.
How far digging into the motor should we go in order to make sure that broken plastic didn't contaminate the whole oil system?
post #9 of 17 Old 03-14-2014, 06:28 PM
NYC F-350's Avatar
Quoted: 51 Post(s)
That doesn't make a bit of sense...How does something stripped out in the fuel system end up in his oil?
Pull the oil filter, check that for the presence of plastic bits too...and check the standpipe.
Please
post #10 of 17 Old 03-14-2014, 06:42 PM
6.0f250firstcar's Avatar
WTF? I'm so confused right now??
SO you're saying the chunks had nothing to do with the problem?
Ryan
6.0f250firstcar is offline
