Am I Being Ripped Off? - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 14 Old 03-12-2014, 07:46 PM Thread Starter
Hi All,
I have a 2000 F350 7.3L. We drove up from Fla and the truck ran pretty good, other than having to replace a water pump in Mo & fuel filter. We had glow plugs worked on before we left Fla and the heater block checked. The day after we got here the truck would crank, but not fire. It has 2 brand new batteries, but I believe had gotten run down from trying to crank it for 2 weeks and the cold weather.
We had the truck towed to a mechanic today. We thought the fuel had gelled up, but they said the fuel system is ok, and they are saying it is the low pressure oil pump and will run $3700.00 to fix, due to having to take out the engine to get to it.
I have a hard time believing it would cost that much from a $100 part, from what I have found on the forum. The Ford dealership in Mo. who replaced the water pump did a diagnostic on it and the low pressure pump was not mentioned and I find it hard to believe the next day it would go out.
Any help or suggestions would be appreciated!
cthen is offline
post #2 of 14 Old 03-12-2014, 08:06 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Hard to say what your problem is without any information on ICP volts, IPR %, rpms while cranking, verified status of CPS... Etc..... So many possible problems and zero info. Its possible for the LPOP to go out, but it's pretty rare.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 14 Old 03-12-2014, 09:12 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
isnt the lpop behind the front cover?
i dont think the engine needs to be removed.
blue99stroker is offline
post #4 of 14 Old 03-13-2014, 04:28 AM Thread Starter
I will try & get more info from the mechanic. Could a low battery effect the rpm's while cranking? I appreciate the help. I just don't want to waste $3700 & I really don't think that is the problem.
cthen is offline
post #5 of 14 Old 03-13-2014, 05:15 AM
Absolutely. What is the cold cranking amperage rating of your batteries? My truck did fine in the summer here in Florida with the cheap 700 cold cranking amp Wal-Mart batteries but when the temps got below 40* it was noticeably slower cranking. I got new 850 cca Motorcraft batteries and it fires off just fine at 18*. If it were me, I haul it out of there with a wrecker would get a second opinion.
1997 F350 XLT Crewcab Dually in Oxford White, The Legendary 7.3 Powerstroke, E4OD with Billet Torque Convertor, 8 Ft. Bed, 4:10 Limited Slip, MBRP 4" Turbo Back, Edge Programmer
badbart is offline
post #6 of 14 Old 03-13-2014, 05:16 AM
I had work truck taken to the shop because it wouldn't start. Thought it was the hpop but I'm not very sharp the on the 7.3s. Ended up needing batteries. Apparently one of them wasn't powering something sufficiently and it wouldn't start.
Brett
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
post #7 of 14 Old 03-13-2014, 09:04 AM
Quoted: 8 Post(s)
If your spending $3700 and you have doubts. Research a reputable diesel mechanic in your area and get a second opinion.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #8 of 14 Old 03-13-2014, 09:08 AM
layson's Avatar
Quoted: 80 Post(s)
Sounds a little steep on price and you don't need to take the motor out to do the low pressure oil pump. I don't think those pumps just go out like that.
It has to be something else. I would think either battery related, or it has to do with the high pressure oil pump/IPR... that kind of stuff.
Or even just check the stupid electrical stuff. Like the main wire harness plugs, the valve cover plugs, etc... since someone was in there working something just may have worked loose.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #9 of 14 Old 03-13-2014, 09:09 AM
layson's Avatar
Quoted: 80 Post(s)
Yes yes yes.... For that price I would talk to someone else.
Quote of the Day:
layson is offline
post #10 of 14 Old 03-13-2014, 04:20 PM Thread Starter
I found out today it's the timing cover that needs to be replaced. I'm still leery and checking into other places. I believe the engine does have to be pulled for that, but I did get them down to $3400...Still really steep I think.
cthen is offline
