Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 11-10-2008, 07:59 AM
JLElectric JLElectric is offline
Oil leak causing vibration and noise under truck????
2001 7.3 4x4, 35" tires, I have an oil leak on top of motor dripping down back of motor by the bell housing. Oil leak is not the issue Im worried about right now. Going down the highway its getting on driveshaft and everything else. Im getting a bad vibration around 40 MPH but if I engage the brake it stops. I think the oil is causing it. I dont know if its off balancing the driveshaft. Im 600 miles from home. Just need to know what step to take.
Old 11-10-2008, 08:06 AM
symbols symbols is offline
Nonsense specialist
Sounds like u-joints or carrier bearing to me. Have you checked them?
Old 11-10-2008, 08:31 AM
SCUFFY828 SCUFFY828 is offline
FORD MASTER DIESEL TECH
if you hit the brakes and it quits , then its very well a hub bearing or brake issue , hitting the brakes wouldnt make the vibration go away if it was driveshaft related , one things for sure its not the oil
Old 11-10-2008, 08:54 AM
TheDurtyDeez TheDurtyDeez is offline
If oil cause vibration... wouldnt rain water? I would jack up the front end and start checking bearings, brakes, ect.
Old 11-10-2008, 09:00 AM
Nonsense specialist
Your right now that I think about it.
Old 11-10-2008, 09:08 AM
bigred_stroker bigred_stroker is offline
Not disagreeing with you one bit scuffy828, but I would still check the U-joints. Mine did the same (vibration went away when I let off the accel, and when I pushed on the brakes (vibration was still there but not near noticable)) And it ended up being my rear U-joint.
Old 11-10-2008, 10:21 AM
I figured it out, the hub assembly. The reason I thought it was oil is because it was all over the brake calipers. If we didnt ask stupid questions we wouldnt need this forum. Now that I think about it the oil thing was pretty stupid.
Old 11-10-2008, 10:23 AM
Nonsense specialist
Glad you got it figured out
