Need 7.3 help asap - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 8 Old 02-22-2014, 04:43 PM Thread Starter
Need 7.3 help asap
Ok need some help while changing my injectors I'm trying to clear the cylinders I sucked the cylinders out with a seringe and turned the motor by hand so after that was done I bumped to over with the key and I'm still getting a bunch of fuel coming out. Can somebody tell me where the fuel is coming from? No injectors in and the injector harness is out. I will say this doing one side at a time so I'm on passenger and driver is all hooked up still
Jmj32988 is offline
post #2 of 8 Old 02-22-2014, 04:54 PM
blue99stroker's Avatar
Quoted: 282 Post(s)
do both sides at once.
pull injectors, put valve covers back on hand tight.
bump starter a few times and your good.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 8 Old 02-22-2014, 05:45 PM
Quoted: 858 Post(s)
Feedback Score: 3 reviews
Lol. Unhook your IDM plug on the driver side. Big square plug with 11mm bolt. That will kill the fuel pump.
Corey@CNCFAB is online now
post #4 of 8 Old 02-22-2014, 06:22 PM Thread Starter
Can I just pull fuse pump fuse? Should do the same thing huh. And you taking about the other plug on valve cover
Jmj32988 is offline
post #5 of 8 Old 02-23-2014, 12:30 AM
Quoted: 858 Post(s)
It will, but you have to remove the plug anyway when you do the driver side.
post #6 of 8 Old 02-23-2014, 03:57 PM Thread Starter
Well I got it put back together and now I hear a slight knock any ideas
Jmj32988 is offline
post #7 of 8 Old 02-23-2014, 03:59 PM Thread Starter
Could it be maybe the injectors didn't seat? I got them in and tapped them with a mallet and I could hear them bottom out and I torqued to spec
Jmj32988 is offline
post #8 of 8 Old 02-23-2014, 05:46 PM
Quoted: 858 Post(s)
Thats air in the oil system it will take about 45 of highway driving to get it bled out.
