need help truck wont start - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 8 Old 02-21-2014, 08:23 PM Thread Starter
twitch02xx's Avatar
Replaced oil cooler today once everything was back together cycled key a few times to prime fuel system and it cranked up and ran for 15 secs then died and have not been able to get restarted unless using ether but dies once that is gone.
Getting 5 psi on low side pressure but only getting 100-200 psi at rail, have cracked fuel lines and manually ran pump for few mins, but can't get it goin.
Any advice
08 CCLB 4WD, 6" BDS, 20" FUEL OCTANE, 37" TOYO OPEN COUNTRY MT, HD300, CAT 1 ELC,
FLOPRO 5" TB, EGR DELETE WITH ELBOW, CAC PIPE, DIESELSITE COOLANT FILTER, EDGE INSIGHT
AFE STAGE 2 CAI, ARP STUDS
twitch02xx is offline
post #2 of 8 Old 02-22-2014, 05:30 AM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
Find out why that is, that is your problem.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 8 Old 02-22-2014, 04:36 PM Thread Starter
twitch02xx's Avatar
Is it to high or low what is normal
post #4 of 8 Old 02-22-2014, 04:45 PM
NYC F-350's Avatar
Quoted: 49 Post(s)
Sorry, my mistake. Completely and totally read that wrong. My apologies
Please
post #5 of 8 Old 02-22-2014, 08:21 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 350 Post(s)
Pop off your oil filter and have someone turn engine over to see if LPOP will pump oil into housing. If so thats good news. If its incredibly slow or even pumps at all then id say you lpop gears are either toast or front cover may be damaged which you don't want. Best of Luck.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #6 of 8 Old 02-22-2014, 08:25 PM
NYC F-350's Avatar
Quoted: 49 Post(s)
You know,,,, that is pretty much what I was thinking too..but then I looked at his sig and it shows that he has an 08. Doesn't that have a low pressure fuel pump and a high pressure fuel pump?
Please
post #7 of 8 Old 02-23-2014, 06:01 AM Thread Starter
twitch02xx's Avatar
Yes low pressure and high pressure fuel system
post #8 of 8 Old 02-23-2014, 10:41 AM
LoxDiesel's Avatar
Quoted: 350 Post(s)
Oooops thought it was a 6.0 my apologies.
@loxdce
