6.0 911!!! - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 9 Old 02-03-2014, 08:02 PM Thread Starter
bigyellow's Avatar
6.0 911!!!
I recently picked up a 6.0 and it needed the obligatory egr and oil cooler, as well as HPOP fitting. Everything went well until...!!!
I needed to get the hpop cover off and it wouldn't budge. I stuck a screwdriver in the large oil tube that goes directly into the HPOP reservoir. I pried a bit and POP! A piece of the cast iron tube broke off and went straight into the HPOP reservoir!!!!
I figured out too late, that some worthless being put silicon sealant all under the reservoir lid and it is stuck!! It will not come off, I will make it come off, but that piece of cast iron that fell in, is that going to go down inside my engine and destroy everything, or...?
What do I do? I have plenty of experience working on diesels, this is new.
The piece that broke off was about 1/4"x1/4"
bigyellow is offline
post #2 of 9 Old 02-03-2014, 08:08 PM
6.0newb!'s Avatar
Quoted: 17 Post(s)
Get that cover off and fish around with a magnet... Good luck!!!
06 f-250 ECSB xlt fx4, MBRP 4" cool duals, AFE stage 2 intake, BPD water pump, BPD egr cooler, stc update, stand pipes, dummy plugs, blue spring, late 04 up pipe, wicked wheel 2, PMM coolant filter, Riff Raff ic boots, t6-5w40, Rotella elc, leveling kit with 350 blocks, Pro Comp pro runner shocks, full Powerstop z36 brakes, PHP ficm tuner, insight cts w/egt, SCT x3 with canned tunes...... for now
6.0newb! is offline
post #3 of 9 Old 02-03-2014, 08:19 PM Thread Starter
bigyellow's Avatar
How far can it go?
post #4 of 9 Old 02-03-2014, 08:23 PM
6.0newb!'s Avatar
Quoted: 17 Post(s)
Well hopefully since the oil is kinda tacky and kinda holds small objects, it might not have got past the pump, but if it's heavy and small enough, all the way to the pan
6.0newb! is offline
post #5 of 9 Old 02-03-2014, 08:26 PM Thread Starter
bigyellow's Avatar
Thanks. This sucks.
post #6 of 9 Old 02-03-2014, 08:33 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
What year truck are you dealing with?
dhanna6powerstroke is offline
post #7 of 9 Old 02-03-2014, 08:55 PM Thread Starter
bigyellow's Avatar
2007. Its a piece of aluminum. It chipped off like cast iron would.
post #8 of 9 Old 02-03-2014, 08:57 PM Thread Starter
bigyellow's Avatar
Someone on the nation helped me out. Its not fixed yet, but I know what to do now. Thanks for all the help!
post #9 of 9 Old 02-03-2014, 11:16 PM
6.0newb!'s Avatar
Quoted: 17 Post(s)
Watcha gotta do?
6.0newb! is offline
