brakes not working - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 4 Old 01-15-2014, 04:54 PM Thread Starter
brakes not working HELP please
working on my 96 f350 with the engine running you push on the brake pedal it goes to the floor you can pump the pedal up but it will fade with the engine off it will not fade I've put new calipers on the front so i could bleed the system and tried 3 different master cylinders but nothing seems to work help please
UPDATE the entire brake system has been replaced vac pump, vac booster, 5 master cylinders, all the steel lines, all rubber lines, wheel cylinders, shoes, hardware kit, drums and properly adjusted. front calipers, rotors, and pads. also bypassed the abs module. it's properly bleed we pedal, pressure, vacuum, and gravity bleed the system any help would be much appreciated
roadkillwi is offline
post #2 of 4 Old 01-22-2014, 04:31 PM
midnite rider's Avatar
Quoted: 285 Post(s)
u listed everything possible that it could be are you sure u do not have a vac leak to the booster
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #3 of 4 Old 01-22-2014, 05:41 PM Thread Starter
im getting 25 pounds of vacuum at the booster and the booster holds vac for a long while with engine off
post #4 of 4 Old 01-23-2014, 03:09 PM
Quoted: 285 Post(s)
now i am stumped, i`ll talk to my buddy see if he can figure it out he`s a 7.3 guru
-Tom
