Heat won't blow. - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 5 Old 12-24-2013, 03:31 PM Thread Starter
josh.williams506's Avatar
Heat won't blow.
The heat and ac will not blow. It comes out just enough to feel with my hand onthe vent. Once I'm on the interstate I can feel it a little more. I checked the fuse and didn't see a bad one. Any possible explanation?
01 f250 ecsb.
6637 intake, wicked wheel, mbrp 4 in turbo back exhaust
Southbend clutch, 6 pos with swamps tunes
josh.williams506 is offline
post #2 of 5 Old 12-24-2013, 03:33 PM
john galt's Avatar
Quoted: 1226 Post(s)
dead blower fan?
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is online now
post #3 of 5 Old 12-24-2013, 03:55 PM Thread Starter
How can I check that? I don't have much knowledge with heating and cooling.
01 f250 ecsb.
post #4 of 5 Old 12-25-2013, 06:56 PM
john galt's Avatar
I would guess if it doesnt blow air and you don't hear the fan it is likely the fan. that is how it has been on most of my trucks. ONE exception is my old truck had a wiring harness burn up and I had to rewire part of the fan switch connector. you could try pulling the blower fan and jumping it with a hot wire and if it blows it could be a switch or wiring most likely the switch, wiring would be pretty rare and saved for folks with luck like...mine
I am still new to super duties so perhaps someone with more wrench time than I will chime in and make sure we are going the right direction
I like mead
post #5 of 5 Old 12-25-2013, 06:59 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
If you can hear it running,is it coming out of the wind shield defrost and not out of the dash in to your face?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
