Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 09-01-2008, 11:14 AM
madscientist madscientist is offline
Rear Brakes
i replaced the rear brakes on my 04 F250 yesterday, after about 20 miles, i get a clicking/clunking coming from the rear of the truck. the sound increases with speed. i checked over everything this morning and cant find anything wrong with the brakes.
this is my first brake job on an f 250 but i have done several others in the past, and the truck is completely stock
Old 09-01-2008, 11:20 AM
dieseldan2005 dieseldan2005 is offline
If it aint a CAT itsa DOG
Did you put new rotors on too? Did you put on new e-brake pads? Sometimes you can get rust chunks in the e-brake drum that will clunk. I tried to replace my e-brake and ended up tearing it out cause it was so hard to get the new springs in.
Old 09-01-2008, 11:29 AM
yes, i replaced the rotors, i looked in the e-brake and around the rotor for rust chucks and blew it out with air
Old 09-01-2008, 03:31 PM
any other ideas?
Old 09-01-2008, 03:36 PM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
Did you clean the rotors with brake cleaner before hand. If not the preservative used on them to prevent them from rusting on the shelf. This coating which is like a grease if not removed prior to installing the rotors can cause a lot of things to happen, clunking, poor braking, that stuff when it gets warm from braking gets goey. Then it builds up on the pads.
Old 09-01-2008, 04:57 PM
yes i cleaned them, when i took it all apart when i got home i found the clip and screw from the parking brake fell off
thank you for your help, /thread
