Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 08-21-2008, 08:22 AM
911 HELP HELP!!!!!!!!!
GUYS,
I HAVE A 2003 DUALLY WITH THE 6.0. IT STARTED MAKING A RATLLE NOISE AT IDLE AND LOW RPM.
I TOOK IT TO THE DEALER THINKING IT WAS A TRANNIE PROBLEM (LOOSE FLYWHEEL OR TORQUE CONVERTER) COVERED UNDER WARRENTY.
THEY TOLD ME THAT IT WAS THE EGR VALVE!
WILL THAT MAKE THIS SOUND?????
HELP FAST, I DON'T WANT TO CHASE SHADOWES, THANKS
Old 08-21-2008, 08:24 AM
im not sure myself but somebody will come along to help ya out to the top
FORD TECH AND ADMIN ....
is it smoking when its making that sound
Old 08-21-2008, 08:33 AM
HEY
NOT REALLY SMOKEING JUST NOISE
IT EXCELERATES GOOD, JUST THE DAMMMMM NOISE.
THEY SAYED THE NOISE WAS FROM DETONATION AT IDLE WITH THE EGR OPEN,
AFTER I GIVE HER GAS SHE QUIETS DOWN BUT GETS LOUD AGAIN AS SOON AS I LET OFF THE GAS.
I WATCHED A YOU TUBE VIDEO THAT HAD THE SAME SOUND AND THE GUY SAID IT WAS A STUCK EGR. BUT I WANT TO FIRM THIS MYSTERY UP BEFORE I SPEND 375 ON A NEW ONE.
THANKS
Old 08-21-2008, 08:47 AM
most of the time when an egr valve is sticking open, yes it could make that noise ,but usually will have smoke along with it , knowing the egr problems a 6.0 is plagued with , its very possible
Old 08-21-2008, 08:54 AM
thanks
THANKS MAN !!!!!!!!!
WHAT SHOULD I DO?
ALL MY MONEY IS PUT IN THE TRUCK ALREADY AND CANT AFFORD A NEW EGR RIGHT NOW.
I TOLD THE DEALER THEY WERE FULL OF SH^$& BECAUSE I HAD NEVER HEARD SUCH A NOISE FROM A EGR VALVE. I GUESS I NEED TO APPOLOGIZE TO THEM.
I HAVE A EDGE WITH JUICE PLATINUM PROGRAMMER AND 5'' STACKS, WILL THIS HELP OR HURT, IN THE FUTURE?
Old 08-21-2008, 08:59 AM
what i woud do is pul the egr valve and see if its clogged or stuck open, clean it , i usually dont tell people that but if you dont have the money try to clean it , make sure its not hung open and try it , the reason for the noise is like in a gas engine , its like a spark knock but a hel of alot louder in a diesel , im not sure if thats your problem or not , but try what i said and see , let us know
Old 08-21-2008, 09:01 AM
WILL DO
THANKS SO MUCH
I WILL LET YOU GUYS KNOW TONIGHT.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
