Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 08-19-2008, 09:16 AM
Mustang1989 Mustang1989 is offline
05 6.0 wont start
I've got an '05 F250 with 125k miles that wont start this morning. It's completely stock except for exhaust. I went outside to start it, and it cranks, but won't start. It worked just fine yesterday going to and from work. On my way home yesterday I was nearly empty, and filled the tank half-way. Bad fuel maybe? I checked my fuses, and their all good. I'm not sure about the relays. My batteries are at 8.5 and 9v while not running. Is that too low?
Thanks
Old 08-19-2008, 09:32 AM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
if its not spinning fast enough and modules arent getting enough voltage it will never start
Old 08-19-2008, 09:35 AM
Strokin & Smokin Strokin & Smokin is offline
Jersey Strokers, Director
Send a message via AIM to Strokin & Smokin Send a message via Yahoo to Strokin & Smokin
put a charger on it, check your fuel filters, both on the frame and on top of the motor. i would say that you picked up dirt/water from the bottom of your tank going that low in fuel. a 12v batt should be sitting in the 13 voltage range, then under load they should drop til about 10 volts. my batteries are new and mine go dead all the time.
hope this helped....
Old 08-19-2008, 10:36 AM
I've got a charger on it, but it still won't start. I'd change the fuel filters, but since the truck is parked in the street I'd probably lose my legs in no time fast! I guess my only option now is to get it towed to the shop.
Old 08-19-2008, 10:55 AM
Heat Heat is offline
My batteries where both on the weak side sometime ago. I'd put them on the charger for about an hour then turn the charger over to "start" and it would just barely start. I drove over to the closest Auto Zone, bought two new batteries, leaving it running while I was there, got home and changed them out. Problem simply no longer exists. It seems, even though there are two batteries, that these diesels seriously require proper voltage and draw to start.
Ken....
Old 08-20-2008, 09:49 AM
The shop called me this morning and said they can't find anything wrong with it. It's started for them every time since they got it yesterday. The guy I talked to also said there were no codes stored in memory. What is going on with my truck? Any ideas?
Old 08-20-2008, 11:40 AM
Evil Eye Evil Eye is offline
Slacker Mod
Ummm, batteries perhaps...
