Please help - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 7 Old 11-20-2013, 11:58 PM Thread Starter
Please help
Hi I just bought an 01 7.3 the truck ran great through the test drive, the feller said it had ran great, he was hauling round bales with it and had a ton of power. Now when I drove it home, the drive is about 2 1/2 hours long, it was running good I could tell there was a u joint issue, no biggie, but when I got about a half hour from home it started losing power you couldn't hear that ford diesel grr grr grr you normally have (you'd know what I mean if you could here my sound effect) and when I'd push the pedal there'd be no power. When id let off I'd hit that spot and I could slowly creep it up to a decent speed, but lose power again, the feller behind me said every time I'd try to rev it up he'd see smoke, and a strong diesel smell (at 50mph) now the temp dropped to about -30 c when this started happening. When I was looking at the truck we'd have it in and out of the warm shop, test driving with less than an eighth of a tank of fuel. After I bought it I fuelled up at the nearest gas station, now could this be a bad fuel filter, bad fuel, injectors or what, and could this cause the engine light to come on I'm stumped please help
Ol01 is offline
post #2 of 7 Old 11-21-2013, 06:56 PM
Quoted: 267 Post(s)
bad fuel/filters/pump
2005 F350 srw Crewcab lariat. 6.0 diesel
nitrogen is offline
post #3 of 7 Old 11-21-2013, 08:03 PM Thread Starter
It's running a 1211 code I found out
Ol01 is offline
post #4 of 7 Old 11-21-2013, 08:04 PM Thread Starter
And now it stalls every time I slow down to turn a corner
Ol01 is offline
post #5 of 7 Old 11-21-2013, 10:11 PM
blue99stroker's Avatar
Quoted: 289 Post(s)
p1211 is icp related. injection pressure above/below desired
the icp is located on the drivers side head, towards the front.
pull it and see if theirs oil coming through it. if their is oil coming through it its time for a new one.
also check your fuel filter and possibly change it just to see if it helps.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger/sonnax shift kits, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #6 of 7 Old 11-22-2013, 03:38 AM
JustinOOO9's Avatar
Quoted: 583 Post(s)
Garage
if your driving around with a super low amount of fuel in the tank, it can be circulating junk from tank so I would look at fuel filter anyways along with ICP sensor. both are not all the expensive considering diesels in general.
if you were getting a miss possibly injectors. was the smoke, white, back, blue?
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s, JW Vbody.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #7 of 7 Old 11-22-2013, 08:17 AM Thread Starter
It was tough to tell what color the smoke was it was about 1 in the morning. I changed my fuel filter yesterday but still no change. I talked to my mechanic and he quoted me about $800 give or take to get it and put er in
Ol01 is offline
