Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 07-19-2008, 04:04 PM
bigcountry bigcountry is offline
Cool motor will turn but not crank
i got a 99 ford f250 superduty 7.3 the motor will spin over but not crank i have replaced the camshaft position senor any ideas ?
Old 07-19-2008, 04:52 PM
sea71 sea71 is offline
Check the oil level in the high pressure oil pump. Remove the allen plug on the top, and the oil should be within 1 inch of the top. If its leaked down, fill it back up. If its low, it wont start. Thats one possibility.
Old 07-19-2008, 06:24 PM
Marty Marty is offline
International Threat
Yup, low oil will keep it from starting.
Any codes?
Batteries need to be perfect. A chip installed???
Old 07-20-2008, 08:04 PM
bryanbrown bryanbrown is offline
is the tach moving while it's cranking. Maybe both cps's are bad. Unlikely, but possible
Old 07-20-2008, 09:25 PM
wingnut wingnut is offline
...try disconnecting the battery for ~10 minutes, hook 'er back up and try it again.
dont ask me why, but my buddy has a 99 that he has to do this to every now and again...and thats with the CPS recall done
Old 07-20-2008, 11:21 PM
Drepka Drepka is offline
Send a message via Yahoo to Drepka
Check the batteries and go ahead and hook some jumper cables up on the thing it may start then. I had the same trouble a couple of days ago, my truck would crank like hell but no start, I could hear a buzzing sound under the hood when i first turned the key on and through the dash. I hooked up some cables and bam the buzzing stopped and it fired right off. I think it was the glow plug relay not getting enuf power.
Old 07-23-2008, 04:42 PM
Any codes?
no codes super chip in stalled
Old 07-23-2008, 04:44 PM
rankroddin250 rankroddin250 is offline
itll spin over but not crank? isnt that kinda the same thing? im assuming you mean spin over/crank over but wont start?
any ways check all of your fuses and make sure none are blown. make sure you have over 11 volts in your batterys while cranking. if not the IDM will not have enought power to fire the injectors. check the high preasure oil resurvour and make sure its full, change the cps if none of the above is wrong. good luck.
Old 07-23-2008, 04:50 PM
outlawdiesel outlawdiesel is offline
Thumbs up fix psd
hows the fuel pressure.and oil rail pressure? clogged fuel line or o-ring is my guess.
Old 07-23-2008, 04:54 PM
ford99PSD ford99PSD is offline
i have seen this somewhere before. in another thread are you sure its not a joke?
