Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 07-04-2008, 02:33 PM
wrs8574 wrs8574 is offline
Send a message via AIM to wrs8574
No Start
Here are the basics.
01 F250 7.3 PSD
Two yellow top Optima batteries bought 1.5 years ago.
Switched yesterday finally from an Airaid Quickfit intake system to an AFE Stage II Pro Guard 7 system. After replacing the entire battery tray area with the new AFE tray everything looked tight and in normal working order.
Went to check it by cranking the engine and it just turned and turned and turned with no fire up. There is a clicking sound coming from my inside fuse panel yet all fuses show no issues. I've checked the under hood fuses as well and nothing there also problem wise. When the ignition is turned backward to accessory it fires my onboard air compressor right up and fills it. When I turn the ignition forward to crank it it doesn't do squat. Both battery connections are fine and hooked up positive to positive and negative to negative.
I'm stumped and stuck. Please any info would be useful. I'm going to pull the battery tomorrow and bench test it but when I first turned the truck over last night it cranked somewhat fine, the truck just wouldn't f**king start.
Old 08-10-2008, 12:38 AM
flyin hawaiian flyin hawaiian is offline
PREMIUM OUTLAW MEMBER!!!!
Thumbs up psd
starter or starter switch.
Old 08-10-2008, 06:32 AM
WEWILLE WEWILLE is offline
What do ya mean by crank and crank. and if you turn the ignition to crank and it wont to squat? If the motor doesnt turn over and your getting a clicking that means you have a dead battery
Old 08-10-2008, 06:42 AM
Dave Dave is offline
Broken shoulder mod
Im hoping he got it taken care of by now guys this post is over a month old
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
