Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
  #11 (permalink)
Old 07-03-2008, 01:52 PM
mdkallam130 mdkallam130 is offline
Send a message via AIM to mdkallam130
Yes thats what im talking about. the hose is about the same size as a straw and snakes its way from the bottom of the drain to the lower portion of the motor where it drains out when you open the valve
  #12 (permalink)
Old 07-05-2008, 06:16 AM
rumaco rumaco is offline
IT IS THE FUEL FILTER DRAIN LINE............CHANGE IT (THERE IS A KIT)
  #13 (permalink)
Old 07-05-2008, 06:17 AM
It goes bad and there is a kit that is simple to replace. Comes with new seal and lever. Happens all the time............not to worry!
  #14 (permalink)
Old 07-05-2008, 07:48 AM
donald lorbeske donald lorbeske is offline
check your drainvalve this biojunk play h ll on o rings my freind had the same thing happen when it heated up it would leak
  #15 (permalink)
Old 09-21-2008, 08:11 AM
RodH RodH is offline
That is the filter drain tube, check and make sure your filter drain valve is closed. Might need to replace the O-rings.
  #16 (permalink)
Old 10-15-2008, 04:08 PM
blowinsmoke blowinsmoke is offline
does anyone have the link with the pictures to replace the o rings and lever. Mine is going south on me as well???
  #17 (permalink)
Old 10-15-2008, 04:18 PM
Nevermind...found it
  #18 (permalink)
Old 10-15-2008, 11:28 PM
its easy, 2 screws, find O'rings a local parts store, unless the lever is broken no need to replace. If its is broken Ford has a replacement kit for the entire valve not to expensive.
