2000 7.3 help neeededddd please - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 5 Old 10-04-2013, 07:11 PM Thread Starter
hi im new here and cant figure out a problem ive been having. diagnosed pretty much everything i could think of. well i replaced the injector seals, glow plugs, and valve cover gasket. its all back together but the truck will not start (sounds like when the glow plugs go on everything lacks power). ive charged the batterys about five times and they read twelve volts when i hook it all up but once the key turns they drop to about 9.47. also i checked the volts to the glows plugs its about 8.50 volts. after replacing the solenoid the truck sounds a little better but when key on wait for the wait to start light to go off there is a clicking sound coming from the number 34 relay in the distribution block. also the glow plug relay clicks on and off. motor will not crank or start all because of the voltage drop. hopefully someones had the same problem before. any input will help out going on day 4 of trying to figure it out lol. driving me crazy
white7.3l is offline
post #2 of 5 Old 10-04-2013, 07:29 PM
Load test your batteries, I've seen batteries volt test fine with no load but as soon as you load test them they fall on their face. That's your first step.
[SIGPIC][/SIGPIC]2006 Black F-350 CCSB 4x4. 6" Fabtech lift, 325/65R20 Nitto's. Deleted and studded, updated stand pipes & dummy plugs, STC gone, SCT Tuned by Innovative & Quick Tricks, Edge CTS, Powermax, 4" dual straight pipe, Intake, FASS Titanium, Blue spring & 6.4 banjos, Sinister coolant filter, ELC coolant, MBRP intercooler pipes and Elbow.
Diesel Tech @ Certified Injection Service in SLC
Friz186 is offline
post #3 of 5 Old 10-04-2013, 07:51 PM
usteffenhagen's Avatar
Not to insult your intelligence, but have you checked your battery terminals/ cables? corrosion? Burnt wires? Exact same problem on mine a few months ago only mine would crank but usually wouldn't start. Cut back the wire, got new connectors and I was rollin'
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #4 of 5 Old 10-05-2013, 11:51 PM Thread Starter
Thank you all for the help. Battery being dead was the problem. Cant say thank you enough!!!!
post #5 of 5 Old 10-06-2013, 10:10 AM
Glad you got it up and running!!
Friz186 is offline
