ford 6.0 04 HELP!! - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 11 Old 09-29-2013, 07:03 PM Thread Starter
ford 6.0 04 HELP!!
I have a bucking and jerking 6.0 right now. It will buck and then won't go above 2000rpm or it will lurch or if I hold the pedal down lose power unless I drop it below 2000rpm. if i put the pedal down the truck wont go above 2000rpm and will go up on speed. the erg was deleted but its trowing crazy amount of white smoke from the exhaust. when the truck starts up some white smoke comes out
but eventually clears up when you keep it under 2000rpm.
when on idle you can step down the pedal and hear the truck failing on revs like an injector issue but i checked and they arent the problem. the problem got fixed for a couple of weeks when i changed the Y pipe because the other was ruptured but the problem came back and its even worse now i can use the truck for nothing.
PLEASE HELP!!!!!!!!!!hn oes:hnoe s:
crissg93 is offline
post #2 of 11 Old 09-29-2013, 07:12 PM
chancelor's Avatar
lack of fuel? fuel filters?
2006 F350 4X4 Lariat... Just getting started with this one... afe air intake, edge juice platinum with attitude, coolant filter kit, high idle switch added, blue spring conversion Fan clutch switch, daystar leveling kit, zoodad, a few extra lights, custom gooseneck hitch and air bags on the rear
chancelor is offline
post #3 of 11 Old 09-29-2013, 07:19 PM
White smoke is either too much fuel like a stuck injector or coolant, ala head gasket failure.
sent from my clickity clack internet phone.
2006 White F350 CCLB 2WD
dowmace is offline
post #4 of 11 Old 09-29-2013, 07:27 PM Thread Starter
fuel filters are new put them in a couple of weeks back. the white smoke is horrible its crazy how much it spills out when you rev the engine.. it could be the head gaskets but i alrdy did the studs so im at a lost here :/
crissg93 is offline
post #5 of 11 Old 09-29-2013, 08:08 PM
Does the smoke smell like fuel? Oil?
[SIGPIC][/SIGPIC]2006 Black F-350 CCSB 4x4. 6" Fabtech lift, 325/65R20 Nitto's. Deleted and studded, updated stand pipes & dummy plugs, STC gone, SCT Tuned by Innovative & Quick Tricks, Edge CTS, Powermax, 4" dual straight pipe, Intake, FASS Titanium, Blue spring & 6.4 banjos, Sinister coolant filter, ELC coolant, MBRP intercooler pipes and Elbow.
Diesel Tech @ Certified Injection Service in SLC
Friz186 is offline
post #6 of 11 Old 09-29-2013, 08:13 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Just because you did studs, doesn't mean it's not a head gasket issue. Lots of guys need there head gaskets replaced for a second time. Depends on what gaskets where uses, what shape the heads were, and how heads where fixed before being reinstalled. I'd pull the injectors and check the cups and o-rings... If they are good, I'd check the coolant for exhaust gas.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #7 of 11 Old 09-30-2013, 05:51 AM Thread Starter
the smell is raw fuel burning lots of it... thing is i just got diagnosed with 2 injectors failing.
would 2 injectors cause this fall in power and this lack of perfomance to the point where the truck is unusable?
crissg93 is offline
post #8 of 11 Old 09-30-2013, 05:55 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
you basiclly now have a 6cyl...and to answer your question.Yes
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 11 Old 09-30-2013, 07:04 AM
Absolutely. Sounds like they are stuck open pouring fuel in the cylinders.
dowmace is offline
post #10 of 11 Old 09-30-2013, 07:57 AM
Quoted: 8 Post(s)
Stuck spool valve... Whatever injectors were said to be bad is where I'd start. Just take them apart your self. Twoiceburgs has a few videos showing exactly how to fix a stick spool valves. If not the spool valves, I'd dig deeper into the injector itself. You might destroy the piston if you keep driving the truck with an injector or two stuck dumping fuel.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
