2003 f250 6.0 starts dies - starts dies- starts runs fine when warm - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 7 Old 09-29-2013, 05:57 PM Thread Starter
Hey everyone new here! Normally I can do a search but didn't have any luck! I just bought a 2003 f250 king ranch fx4 6.0 164,000 miles. When I bought the truck he told me it had a egr delete kit, new oil cooler, new fcim and new hpop but had no receipts to show. I did confirm it has a IPR delete kit and rebuilt fcim so I don't thank he's lying about it.
My problem is when I go to start it and it's been siting over night or all day it will start right up but die almost a few seconds later I can start it back an it will run a bit longer then die again normally the third time it will stay running and I won't have another problem with it. I have changed oil and filter with rottela t. New motorcraft fuel filters and a new air filter. Also I have tested my ficm and got steady 46 volts.
So I'm kinda stuck I really thought it was the fuel filters but it wasn't any help would be great! Thanks
Kingranchsixoh is offline
post #2 of 7 Old 10-02-2013, 09:18 PM
Are you using the stock oil filter cap? Or is it a tall aftermarket one?
[SIGPIC][/SIGPIC]2006 Black F-350 CCSB 4x4. 6" Fabtech lift, 325/65R20 Nitto's. Deleted and studded, updated stand pipes & dummy plugs, STC gone, SCT Tuned by Innovative & Quick Tricks, Edge CTS, Powermax, 4" dual straight pipe, Intake, FASS Titanium, Blue spring & 6.4 banjos, Sinister coolant filter, ELC coolant, MBRP intercooler pipes and Elbow.
Diesel Tech @ Certified Injection Service in SLC
Friz186 is offline
post #3 of 7 Old 10-10-2013, 05:19 PM Thread Starter
I did have a napa filter cap an filter changed that today with motorcraft cap and filter still haveing problem.??
post #4 of 7 Old 10-10-2013, 06:32 PM
Okay I just noticed in your original post you said your FICM has 46 volts? It should around 48-49 volts. Usually when I see them drop to 46 I change them anything less than that can cause a no start condition. With your FICM voltage that low it could very we'll be your problem.
Friz186 is offline
post #5 of 7 Old 01-13-2014, 01:15 AM
SUPERDUTYMIKE is offline
post #6 of 7 Old 06-05-2014, 10:42 AM
I had this same problem and replacing my HPOP fixed it.
2004 Excursion Diesel, 2003 Style Engine, EGR Delete, New Long Block at 141k, Manual Warn Hubs
BenPutnam is offline
post #7 of 7 Old 06-12-2014, 07:10 PM
Yeah, sounds like a ficm. I have also seen people with so many injectors missing cold, that truck wouldnt run for more than a second. When you turn the key in the on position, the injectors cycle. It should sound loud clean and consistant, if it sounds kinda randomized its usually injectors or ficm. Gotta check ficm when first cranking after a long cold soak. Also, if using the block heater fixes the problem, usually ficm/injectors.
If those are good, id look into base oil pressure/icp
Scumbag is offline
