3rd alternator just died within a year help - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 7 Old 09-21-2013, 09:32 PM Thread Starter
THEE RAT's Avatar
Ok guys idk what I'm missing here. But please help lol
Bought my truck in Nov last year.
05 f350
Truck died not to long after buying. A buddy who works at ford said it was my battery's bc the battery light wasn't on. So I bought 2 new battery's. Well a few days later same thing. So took it to his work. Got a brand new shinny alternator.
Boom truck was back. Started like a champ nice and quick. A few months later same thing. I called him, said I got a bad alternator. So he swapped it. Yet again truck was back working perfect.
Now here I am 2 months later and I noticed the truck cranking a little slow today. Then my windows seemed slow up and down. Went to go run to the store quick and truck almost didn't start. Lights were dim. Ran to the store. Left it running. Got home parked her. And just as I thought. Click click click won't turn over.
So if I have had 3 alternators. 2 new battery's. And this keeps happening. What could it be????? Ps kill me
Thanks guys!!!!
SOLD - 02 F350 CC LB DRW 6 speed 2wd
SOLD - 01 F350 CC LB 12inch lift on 24's and 38's
SOLD - E99 CC DRW 2wd 6 speed
TRADED IN THANK GOD! - 2005 DODGE 2500 CC SB
CURRENT-2005 CC DRW 2wd!
THEE RAT is offline
post #2 of 7 Old 09-21-2013, 09:57 PM
Quoted: 858 Post(s)
Feedback Score: 3 reviews
Were the alts OEM? Or did he go to Napa? For some reason the quality requirements for aftermarket alternators for our powerstrokes just isn't there. IMO I think they are putting crappy regulators in them. Make sure there isn't something in your system that isn't drawing power while just sitting.
Fwiw DCPower Engineering is the way to go when it comes to alts
Corey@CNCFAB is online now
post #3 of 7 Old 09-22-2013, 05:06 AM
Quoted: 58 Post(s)
A couple of things:
If you can afford it, get a DC Power alternator in 180 amp or higher size. Your power issues will be solved. If you cannot, go OEM. If you have a single Alt truck then get the 140 amp OEM upper Alt that is used with the dual Alt trucks. It is a direct bolt on replacement for the standard 110 amp upper Alt.
Check you ground wires, and even add some additional cables to parralell the existing ones. Do a search for the "Big 3 upgrade".
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #4 of 7 Old 09-22-2013, 06:03 AM
Term3's Avatar
Quoted: 2 Post(s)
You need to fix your electrical issues soon or you'll be buying a new FICM also.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #5 of 7 Old 09-22-2013, 06:10 AM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 275 Post(s)
X3 on the DC alternator. Its well worth the money just for piece of mind knowing you've got a quality unit, and the truck has the power it needs that an OEM unit cannot provide
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #6 of 7 Old 09-22-2013, 08:50 AM
Quoted: 58 Post(s)
Good point! The OP will need to check the FICM main power voltage once up and running normally. If it's getting low, injectors will get damaged.
Carli Radius Arms
Carli Track Bar
Previous:
All the BPD goodies
skanj0 is offline
post #7 of 7 Old 09-22-2013, 11:52 AM
Term3's Avatar
Quoted: 2 Post(s)
This is a very good point also, I gained a half volt just by changing all my battery cables and cleaning both ground points to bare, clean metal when I did mine with 2/0 cables. I didn't put them in parallel with OEM ones as there wasn't much room in front of the rad once I put the 2/0 cable across.
Term3 is offline
