Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
  #11 (permalink)
Old 05-04-2008, 07:23 PM
97bluestroker 97bluestroker is offline
Send a message via AIM to 97bluestroker
my 97 7.3 has a similar issue... its happend on several occaisions, last summer it ended up to be a loose wire on my alternator. just a few weeks ago it happened again. i unplugged my pcm, cleaned all connections and put that electrode gel stuff on the connectors. it hasn't happened since. mine would do the same thing with the dinging. everyonce in awhile it would do a weird ding and none of the check lights on the dash came on,. thats how i would know it wasnt going to start. hope this helps
  #12 (permalink)
Old 05-04-2008, 07:40 PM
twiztid1981 twiztid1981 is offline
Send a message via Yahoo to twiztid1981
ok she started, as soon as i turned the key i could hear everything under the hood doin its thing then she started right up, what do i need to be lookin at? should i just take it in tommorow cause i dont have the tools or the time to try an troubleshoot this thing
  #13 (permalink)
Old 05-04-2008, 08:43 PM
2005F250 2005F250 is offline
Yep shoulds like your HPOP is going out. Someone of more brains whould cchime in soon.
  #14 (permalink)
Old 05-04-2008, 10:53 PM
Southpaw Southpaw is offline
1/20/2013
You said you have a warranty, I would take it in to the shop. I know you have a busy day, but either your truck is sidelined at a place that will be fixing it for you, or it may be sidelined anyway, getting towed to a place that will fix it for you. I woul;d take it in. Actually I would do it myself, but you already said you didn't want to do that...
good luck
later
  #15 (permalink)
Old 05-08-2008, 10:04 AM
Slartibartfast Slartibartfast is offline
if it cranks and doesn't fire, one simple thing to try is to unplug the cooling fan connector on top of the fan shroud. On some vehicles, the electric part of the fan clutch shorts out, and it takes VREF to 0V so no sensors will work.
