Trailer signal/brake lights not working! HELP - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 2 Old 07-08-2013, 06:29 PM Thread Starter
livinglegend18's Avatar
I have a 2005 f350...I'm not getting brake/ turn signals on my trailer...only running lights I've checked all fuses...even the two relays under the hood? I have no idea what else to do I have about two days to figure it out...I need help
Note* pervious owner had 5th wheel with light hookup in the bed which is no longer there
And I kno it's not my trailer I've tried it on other truck
Thanks!!
05 F-350 SRW SB 6.0 FX4
K&N Air Intake
MBRP 5" straight from down pipe 7" tip
SCT Custom Tune
03 Turbo
08 Tailgate,Tail Lights,Mirrors
Hids 6000k Top/Bottom
Daystar 2.5 leveling kit
Bilstein 5100 Shocks
08 20s
Toyo Open country M/T
35x12.50x20
livinglegend18 is offline
post #2 of 2 Old 07-08-2013, 06:41 PM
superstack's Avatar
I would check the contacts in your trucks plugs for dirt and corrosion and any bent contacts. If that don't work then whip out a test light and see if you are gettin power. If nothing than let the fun begin of tracing wires... Find your ground, mine went bad and this was the same problem I had
superstack is offline
