7.3 starts on its own!!!!! need helpppp - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 5 Old 06-09-2013, 07:14 AM Thread Starter
Angry 7.3 starts on its own!!!!! need helpppp
ok so when to start my truck friday night after a party. smelt this burning smell when i opened the door went to start and wouldnt start so i said f**k it and i got a ride home. got the truck loaded on a trailer yesterday and brought it home. realized it was the starter so i got a new one from advanced. brought it home and put it on truck started up perfectly fine. scooore. but after 10 15 seconds of running the started engaged so i shut the truck off and i was sitting there a min and the truck started to crank again while the key was off so i bought a new ignition switch and selinoid that goes on the fender. now im stumped. i dont know what to do and i really need my truck to go to work with. please helpppp!
james pine is offline
post #2 of 5 Old 06-09-2013, 09:24 AM
Quoted: 133 Post(s)
Feedback Score: 3 reviews
Start at the Key, and trace it forward.
Is the relay on the fenderwell getting the keys signal to throw? Unplug one of the sm wires and see.
If not, and that relay is still sending Big Power to the Starter, THAT relay is Bad.
If so, the Ign Cly is Bad as it shouldn't be completing that circuit when Off.
If everything is OK with those two, then the problem must be with the starter, or the associated wiring connecting to just it.
NoRalPh is offline
post #3 of 5 Old 06-09-2013, 09:38 AM
c69ss396's Avatar
my guess is the starter solenoid is shorted out internally..
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #4 of 5 Old 06-09-2013, 12:03 PM Thread Starter
i replaced the selenoid. i wonder if it could be the relay and do u know witch one it is i dont have a manuel
post #5 of 5 Old 06-09-2013, 01:01 PM
Quoted: 133 Post(s)
What yr Truck? (you should always include that, they're Not all the same)
NoRalPh is offline
