7.3 turns over but not running - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 15 Old 05-09-2013, 06:50 PM Thread Starter
A friend of mine has a 2003 7.3 and it has been running perfectly fine. He was backing a trailer and didn't see the tree and well you can guess the rest. He hit it so hard it bent his draw-tite hitch, he pulled up off the tree and then turned his truck off. We looked over the bent bumper etc. and he attempted to crank the truck with no luck. I thought at first it was the fuel shut off switch on the passenger kick panel but not it. Checked fuses and none are blown, all dash lights are coming on and fuel pump is working and pumping hard. Anyone heard of this happening? Maybe some wires got knocked loose? Why wouldn't it have died before he turned it off then?
Neil26 is offline
post #2 of 15 Old 05-09-2013, 06:59 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Very interesting. Would like to know too.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 15 Old 05-09-2013, 07:10 PM Thread Starter
yeah, me too since it's in my front yard now. When ether is sprayed into the intake it cranks up..so it's simply not getting fuel for whatever reason. Maybe i missed a fuse? (even though i checked 3 times)
Neil26 is offline
post #4 of 15 Old 05-10-2013, 06:55 AM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
My usual No Start -
WTS Light? - do you get it when you first roll-on the key? (shows the computer is running)
Is there fuel in the fuel bowl now? Does it refill after cranking? (open the drain level to check)
Can you hear/feel the pump running (below the dr seat, against the framerail)
Could the fuel gauge be giving a bad reading? (Below 1/4 tank?)
Is your truck "chipped"? If so, remove it as a Test.
AND, on another note, STOP using Either before you damage the engine!
NoRalPh is offline
post #5 of 15 Old 05-10-2013, 09:15 AM Thread Starter
Originally Posted by NoRalPh View Post
My usual No Start -
yeah all lights come on. yes fuel in bowl...it refills, it's not chipped in any way. I know not to use ether but it was the only way to see if it was firing. It won't be used again trust me and i used as little as possible.
Neil26 is offline
post #6 of 15 Old 05-10-2013, 09:19 AM
valhalla1's Avatar
I'm assuming the ether was/is used because originally the glow plugs needed replaced and weren't?
valhalla1 is offline
post #7 of 15 Old 05-10-2013, 09:24 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
CPS?
2000-7.3L is offline
post #8 of 15 Old 05-10-2013, 11:10 AM
battery disconnect for 5 min or so may allow the truck to start
hithebrakes is offline
post #9 of 15 Old 05-10-2013, 11:29 AM
Quoted: 728 Post(s)
Aaahhh. Nooo. Don't use Ether on a Powerstroke. Very very bad. If you need to use a something to assist in startup, i.e. ether, USE WD-40. Works great.
I think you may have missed a fuse. You have fuel up to the bowl but the injectors are not firing. Could be cps, could be fuse for the IDM. If its the IDM fuse the jarring may have finally caused the fuel bowl heater to short since its on the same circuit. If so, then just unhook it and replace fuse.
Corey@CNCFAB is offline
post #10 of 15 Old 05-10-2013, 05:45 PM Thread Starter
Yeah, I will check the fuses again. I'm not sure if he wants to spend the money for cps, he may just take it to the ford dealership. As far as ether..it won't be used again..it was only a one time thing. Thanks for the help
this online manual says it's 105 (30A) if that's the case it's a big square one with a clear plastic cover on it, checked that one and it's looks good and tests good as well.
http://www.motorcraftservice.com/pub.../03f23og1e.pdf
maybe wrong manual?
I'm thinking about checking the pcm relay next
Neil26 is offline
