no brake lights - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 3 Old 05-06-2013, 11:10 AM Thread Starter
george g's Avatar
no brake lights
I have an 04 f250 and the brake lights went out.I still have the third brake light and every other light.I checked fuse no. 18 & 34, anything else would be helpfull.
04 ECSB 4x4 f250 Lariet,looney tune,egr delete,4" diamond eye exhaust,studded water/meth inj. . 04 GTO with a 408 stroker (506hp 468tq.).
george g is offline
post #2 of 3 Old 05-06-2013, 11:55 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Well first off did you check the obvious are the bulbs good? if thats all good id check all fuses because sometimes weird fuses will cause things to go out. if they are all good id guess you have a short somewhere up the line because i believe a fuse would trip all 3 brake lights, take a volt meter and just follow the wires back as far as you can and see if you can see any damage and test.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 3 Old 05-06-2013, 12:29 PM Thread Starter
george g's Avatar
Brake lights came back on when I was looking at how to get at turn signal switch.I guess I'll be changing it soon.
george g is offline
